Author Topic: code 1614  (Read 1205 times)
pauls
  • By the sea minehead
    • Bmw x3
code 1614
« on: 31 October 2013, 18:24:00 »
Changed the battery in the key and a little black thing fell out. Thought owell just a bit of plastic. so i but the key back together and tried it in the car.It started but the car/spanner came up flashing. Turned the engine off and worked out where the bit of plastic went put it back together and tried it all ok. I decided to do the pedal trick and the code came up i take this will go away or will i need to get it cleared.
Re: code 1614
« Reply #1 on: 31 October 2013, 18:29:42 »
From memory. 16xx codes are immobiliser, which would fit in with events. Also from memory, I think it stays there until cleared.
Ignore it ;)
