Wanted from a breaker
Started by JamesV6CDX, 31 October 2013, 18:38:26
2 x pins for rear brake pads in good nick!
Thanks!
Quote from: JamesV6CDX on 31 October 2013, 18:38:26
Thanks!
My spares are depleted, so can't help, but worth stating if vented/non vented, as the pins vary.
Given that they are about £4 each, unless somebody local has them, dealer may be cheaper...
Quote from: TheBoy on 31 October 2013, 19:02:00
Thanks!
Brilliant, dealer it is, cheers! :y
amba
I recentley had real time problems getting a set of rear brake pins for my 3.2 with vented discs from VX.
After a full UK dealer search it ended up needing my local place having to order them direct from Germany.
Eventually arrived some 2 weeks later,so hope they have now replaced the UK stock unless ,like me ,you are not in a hurry.
Not cheap either ,around £4=50 each
biggriffin
Local motor factor do them as a kit 4 pins and 2 shims £11.98 me thinks the factors are CAS.
most good factors list them but remember to state vented or non vented.
Hoof'land storeman.
