Author Topic: Middle Rear Seat Belt  (Read 1020 times)
amba
  • Medway towns
    • German V6
« on: 01 November 2013, 15:51:23 »
Is there a way of removing the seatbelt from the center rear fasterner without unbolting it from the floor pan.
Middle seat belt which I assume is for child seat fitting.....as need to remove rear seat squab and would prefer not to need to unbolt everything
Re: Middle Rear Seat Belt
« Reply #1 on: 01 November 2013, 15:56:08 »
On a saloon, if you mean how to release the actual seatbelt buckle, just press the circular "dot" where the buckle slots in
amba
  • Medway towns
    • German V6
« Reply #2 on: 01 November 2013, 15:58:31 »
Cheers Rob.
There was so much dirt and grime on the seat belt I didn,t even notice the circular "dot".
Will investigate in a while before I need the candles out side  :y
« Reply #3 on: 01 November 2013, 16:00:47 »
It's a normal seat belt for use for child or adult.
http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf page 68  :y
amba
  • Medway towns
    • German V6
« Reply #4 on: 01 November 2013, 16:03:28 »
Cheers Guys  :y
Picked out the dirt and sure enough there is a little push button,which has released the belt so all good,thanks  :y
