Author Topic: lower radiator electrical connector  (Read 888 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« on: 03 November 2013, 12:09:33 »
Can anyone advise how the lower radiator electrical connector, just above the radiator drain valve, disconnects? A picture or diagram would be helpful.
Re: lower radiator electrical connector
« Reply #1 on: 03 November 2013, 12:24:42 »
There's a locking tab on it, best found by feel. If you can get the tip of your finger under the end of it, the plug should pull out :y
It awkward but because it's between the coolant pipe and the subframe/chassis leg you have to work by feel :-\
« Reply #2 on: 03 November 2013, 20:51:55 »
Yep comes off easy once you sus it ;)
I usually get rad half out which gives you room to reach (and sight of) the plug ;)
Page created in 0.101 seconds with 16 queries.
