Author Topic: Saab 9-3 1.9TiD starting issue...  (Read 1227 times)
chrisgixer
« on: 04 November 2013, 12:48:21 »
...when parked on a slope. Turns over, cranks fine. Takes several attempts then fires eventually. Filter changed recently.
Any ideas?
martin42
Re: Saab 9-3 1.9TiD starting issue...
« Reply #1 on: 04 November 2013, 12:58:19 »
Leak of pipes
« Reply #2 on: 04 November 2013, 13:59:16 »
Leak of pipes
If it's parked facing uphill, then as said you may have air leaking into the fuel pipes and all the diesel's run back to the tank.  ::)
Can you see air bubbles in the fuel pipes?  ???
Park it facing downhill!  ;)
    • 530D M Sport, 330i Coupe
« Reply #3 on: 04 November 2013, 20:05:05 »
Starter motor not turning fast enough - documented on a lot of SAAB forums.
