Author Topic: Central Locking issue with passenger front door - microswitch  (Read 1620 times)
Only Me
  • Sunny Hartlepool - no honestly it is sunny
    • Omega 2.2 DTi CDX
Hi All,
I believe I have an issue with the micro switch with my central locking having read various other threads before posting (52 reg 2.2 DTi if that helps)
When I lock the Omega via the remote fob, all doors lock except the N/S/F door. If I open that door the alarm goes off.
When I open the Omega vai the remote fob, all doors open bar the N/S/F door and I have to reach over and pull the tab up.
Can you confirm I have diagnosed the problem correct please?
If so is this the right thread below?
http://www.omegaowners.com/forum/index.php?topic=90642.0
Thanks in Advance  :D
Re: Central Locking issue with passenger front door - microswitch
« Reply #1 on: 06 November 2013, 18:02:37 »
Sounds about right to me. :y :y
you could follow the guide & repair your locking motor or fit A N Other know to be working unit from one of the breakers here. Both fronts are the same  :y
