Author Topic: 2.5 block with 2.6 ecu?  (Read 1328 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 07 November 2013, 18:40:56 »
A strange question, would a 2.5 engine be adaptable to run with a 2.6 ecu , throttle bodies, non egr manifolds etc added to it? if so what else would need to be added to it?
Re: 2.5 block with 2.6 ecu?
« Reply #1 on: 07 November 2013, 19:32:41 »
In theory, yes :y
You'll also need to swap all the sensors from the 2.6 block to the 2.5 :y
The only ifbutmaybe would seem to be the crank and cam sensors, given the problems someone else has been having trying to get a 2.6 block to work with 2.5 management  :-\
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 07 November 2013, 19:54:57 »
Im pretty sure the crank sensor is the same,not sure about the cam . Obviously Throttle position sensor would be needed from the pedal too.
Anything else???
« Reply #3 on: 07 November 2013, 20:09:00 »
If you're putting the 2.5 block into a 2.6 then it should be plug and play, the only exception being the lack of egr and sai :y
Only metioned the crank/cam sensor due the the problem being experienced elsewhere :y
This being the thread that I was refering to...
http://www.omegaowners.com/forum/index.php?topic=119039.0 :y
« Last Edit: 07 November 2013, 20:12:37 by ex taxi al »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 07 November 2013, 20:15:00 »
Cheers its not for me actually it's possibly a 2.6 loom etc going onto a 2.5 engine then the lot into a completely different car as an engine conversion. I guess in this instance the FBW throttle would be a bonus save running a throttle/cruise cable.
« Reply #5 on: 07 November 2013, 20:22:51 »
Will need the throttle pedal then, most of the car loom, and ideally a manual 2.6/3.2 loom... plus 2.6/3.2 plenum and manifolds :y
Any idea what car it's for :-\
