clutch slave cyl spacer
Started by dillan, 12 November 2013, 17:52:48
dillan
Does any have the measuments for the clutch slave cyl spacer when you put the red top flat type flywheel on ???
Should be easy to calulate as it the difference in thickness between the DMF with pressure plate and friction plate fitted and the non DMF with pressure plate and friction plate fitted
