Author Topic: changing thermostat; cannot get out transfer pipe  (Read 1262 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 13 November 2013, 16:01:29 »
OE03EWW 2003 3.2 petrol manual saloon
I am changing the thermostat. I have removed plenum, inlet manifold and black spacer piece. I have remove the power steering reservoir, moved pipes out of the way, and removed the B-bolt. I have dropped the bracket that holds the dip stick (bother), and removed the lifting bracket from behind transfer pipe flange. I cannot move transfer pipe, and am obstructed by dip stick tube. I have not yet removed the two bolts holding down the thermostat. I am stuck.
Should I remove thermostat bolts?
Should I struggle to remove dip stick?
Should I apply more force to transfer pipe flange?
Please advise.
I_want_an_Omega
Re: changing thermostat; cannot get out transfer pipe
« Reply #1 on: 13 November 2013, 16:08:10 »
The big problem I had when I did mine was that the stat and transfer pipe couldn't be separated - without destroying the pipe. The pipe is a casting and can be damaged quite easily. I dont recall any issues in removing things once they were separated .... I had a new stat and pipe ready to go ....... Good luck
« Reply #2 on: 13 November 2013, 16:18:21 »
My approach is to wiggle the stat housing (having removed the bolts) before removing the b-bolt.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 13 November 2013, 16:22:52 »
The transfer pipe is relatively cheap and you get the 2 orings that you will need anyway. get hold of it with mole grips and wiggle it about.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 13 November 2013, 16:56:20 »
I wiggled the thermostat as per guide and sheared the bracket that the B' bolt goes through.  ::) I then had nothing to twist against so I feel your pain.  ;D I bolted the stat back down and butchered the transfer pipe to get it separated. A new transfer pipe is about £12 so not a big loss if you bugger it up.  :y
Get angry with it, it's got to come off one way or another.  :y
Good luck.  :y
« Last Edit: 13 November 2013, 17:01:19 by YZ250 »
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 13 November 2013, 17:59:47 »
Thanks chaps. I tried hammering at the joint, putting pack the B-bolt, unbolting the stat and heaving that about; I put back the stat bolts, removed the B-bolt again, and tried hammering down on the bracket, then with a stilson heaving it back up again. Became resigned to destroying it, and wondered how to go about it. Then wriggled it again and it moved some more, then it came free, and now it's out. Phew!
Thanks again for all the good advice.
Page created in 0.029 seconds with 16 queries.
