Author Topic: 3.2 stalling when pulling up at junctions...  (Read 5670 times)
« on: 14 November 2013, 19:25:44 »
As above... pull up at a roundabout/give way, foot down to pull out, blocks the engine has stopped ::)
Codes are...
0115
0443
0430
0300
0302
0304
It restarts readily enough, but not instantly. Otherwise goes like the proverbial poo from a shovel (cold air helps). Engine is up to temp, fans doing what they should, temp gauge ok. No obvious vac leaks or plugs loose, I only disconnected the injector and rear multiram plugs for the stat change any way :-\ also the idle before it dies is fine but once restarted it hunts a bit, hence the misfire codes I guess...
The purge valve is a known entity, I can recheck the hose and plug easily enough, but which sensor produces the 0115 :-\
Now on 258k, cambelt done at 240k along with plugs/air filter... only started playing up today, and has done 300 miles since stat change, so not convinvced it's related :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: 3.2 stalling when pulling up at junctions...
« Reply #1 on: 14 November 2013, 19:29:28 »
Isn't 0115 coolant temp related  ???
other rides
« Reply #2 on: 14 November 2013, 19:33:55 »
It is :y but is that the sensor on the coolant bridge or one on the radiator?
symes
  • oxford
    • R reg 940 volvo
« Reply #3 on: 14 November 2013, 19:37:02 »
my disc says its 0115= ECM B  no communication---not sure myself but hope that  helps
« Reply #4 on: 14 November 2013, 19:38:37 »
Starting to look like yet another poxy loom :(
« Reply #5 on: 14 November 2013, 20:06:21 »
« Reply #6 on: 14 November 2013, 20:21:30 »
Ta :y
Had another rummage and found the cause of the stalling/mardy idle...
The spring clip on the purge valve hose at the breather bridge had failed and pipe had come off ::)
Press the brake pedal on overrun and the inlet air pressure discrepancy stops it dead.
Can feel nothing wrong with the wiring/plug on that sensor, so guess it's toast... genuine new or chance second hand, don't know how reliable they are...
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #7 on: 14 November 2013, 21:21:52 »
Haven't a clue what one looks like but there is probably one on my 2.6 breaker, get a pic and I'll see if it's there
« Reply #8 on: 14 November 2013, 21:26:21 »
Rob G to Omega help ;D
I think there are only two things screwed into the coolant bridge... the spade terminal sensor for the temp gauge and the other one which would appear to be the ecu temp feed :-\
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #9 on: 14 November 2013, 21:50:49 »
My first V6 would do that, stall occasionally at junctions. Took me months to cure, turned out to be MAF sensor. Easily checked by unplugging.
« Reply #10 on: 14 November 2013, 21:57:45 »
No MAF codes though :y
henryd
  • west cornwall
« Reply #11 on: 14 November 2013, 22:02:04 »
http://images.omegaowners.com/images/guides/v6_cts/IMAGEOFCTS_zpsdc0580fe.png
other rides
« Reply #12 on: 14 November 2013, 22:10:08 »
Ta :y
Looking at that I thought there were three connections, yet was sure that only two were electrical, but couldn't place the third ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #13 on: 14 November 2013, 22:43:44 »
Just pulled the Maf plug of my 3.2, to do a 'not convinced about the mpg on lpg' check, been 3 days now, still waiting for the eml to come on.  ???
« Reply #14 on: 14 November 2013, 22:45:47 »
 ;D did you pull the bulb at the same time ::)
