Saab 9-5
Started by mrgreen, 15 November 2013, 14:19:46
mrgreen
Hi all, i was perusing the used ads over here and came across a saab 9-5 from 99 with the b308(150,000 km) motor in it which the timing belt has jumped a couple of teeth, is this worth fixing? what would i be up against new valves? or is it likely the pistons would be damaged as well? I'm geussing the repair isn't going to be cheap i've done a bit of research but any extra info would be great sa i'm sure there's plenty of people on here that know this lump better than me,
regards,
Rich.
Warning: Dates in Calendar are closer than they appear.
henryd
If its only jumped a couple of teeth it may have escaped any damage at all,worst case though is bent valves,pistons may be marked but don't usually sustain damage
other rides
