seeking wiring help with Vitara rad fan never worked
Started by Varche, 18 November 2013, 15:27:55
Varche
Story so far. The air con rad fan works fine.
Engine rad fan doesn't and never has for two years.
fan works with 12 volts direct from battery.
Replaced the switch in the thermostat body.
I haven't got a wiring diagram( it is a 2002 Spanish built Vitara)
I suspect it is either a fuse or more likely a relay.
I have a multi meter but have never used it!  :-[
Any suggestions welcome. ( took it to an auto electrician today but he wanted it for a whole day 9 a.m. till 8p.m. so hat is a non starter)
Webby the Bear
Check relevant fuses with multimeter (set to continuity and listen for a beep - if your MM has that).
to test the relay you can hook your battery up to the low current side (two pins) and then if the relay clicks its good. an absolute though is to put your MM on the high current pins whilst low current side connected to the battery and get a continuity reading from that also.
if none of that makes sense check out ''eric the car guy - test a relay'' on youtube :)
RIP Paul Lovejoy
Varche
Thanks for that Webby.
I had a quick look and a poke around. I found four big fuses 40 50 60 and 80 and pulled them they all look fine. Found two others in engine compartment too. They are fine. Found the fuse box in car under dash but light was failing.
have had success though with reversing light.  :y Found a disconnected multi plug from reversing light switch on gearbox to loom. Absolute swine to do as it was on top of the gearbox and no room.
I will renew battle tomorrow
Two more questions.
1. What average size fuse are rad fans on? 30A?
2. might there not be a relay in the circuit? I have only found two. One must be part of the air con system.
A couple of things to try:
Can you follow the wiring from the thermoswitch back to a relay perhaps?
If you short the 2 wires at the thermoswitch do you hear a relay click anywhere?
Is there power at either end of the thermoswitch wiring? If so, does it disappear when you unplug one of the relays?
Failing that, put your multimeter on amps, across the thermoswitch and see if any current flows. Does it disappear if you remove one of the relays?
Is there continuity between either of the wires at the thermoswitch and either of the wires to the motor?
I wonder if a Haynes manual would help? (OK, might not be the Spanish model, but would it have changed that much?) Got to be one on ebay for a fiver, perhaps?
