Plastigauge - what's the point?
Started by Webby the Bear, 18 November 2013, 19:58:02
Speaking of.. I read recently one (well respected, if I'm remembering the source correctly) engine builder stating that plastigauge was as useful as a chocolate teapot, and the only way to measure bearing clearances properly was using a micrometer and bore gauge.
If I recall the procedure correctly it was; measure the main bearing shell with the bore gauge (after torquing down the cap), then measure the journal with the micrometer, zero the mic and then measure the bore gauge; that reading is then the clearance..
Wish I could remember where I read it now, whether it was in Barry Rabotnik's book or whether it was Mike Huddart.. the former being much less reliable than the latter!
Quote from: aaronjb on 19 November 2013, 10:47:14
On those old yankee lumps you can measure the clearance with a tape measure, surely? ;)
Nah.. If you can get your fingers between the journal & bearing it's worn, if you can't then it's good for another 200k.. ;D
Quote from: aaronjb on 19 November 2013, 11:12:15
Makes sense. Too many damn 'nummers on the tape measure. ;)
Webby the Bear
save posting a new thread.... ive been learning about thrust bearings.
am i right in thinking they are located along the main bearing journals in the block to locate the crankshaft laterally.... and that you can test it by pressing the clutch pedal and measuring forward crankshaft movement to see if theyre shot? well if thats the case how can you test it on an auto? and am i right in thinking that thrust bearings are poor on omegas? (just remember someone mentioning it :)
RIP Paul Lovejoy
henryd
Quote from: Webby the Bear on 19 November 2013, 18:19:44
Clutch pedal will show you some of the play,better to grab the crank pulley and push/pull it in and out(engine off naturally  :D :D)
other rides
Webby the Bear
Quote from: henryd on 19 November 2013, 18:26:05
;D ;D ;D
can you do that with an auto? i presume you can  :-\
RIP Paul Lovejoy
am i right in thinking they are located along the main bearing journals in the block to locate the crankshaft laterally.... and that you can test it by pressing the clutch pedal and measuring forward crankshaft movement to see if theyre shot?  .....
Pushing the clutch loads up the thrust bearing which is why it's not best practice to press the clutch as you start ...... however on lots of manual cars these days you have to press it to start the car
Webby the Bear
Quote from: Andy B on 19 November 2013, 18:33:28
i know about that. when i worked in edinburgh for a couple months the girls i work with were late. get a call at half 9 ''we cant start the hire car''  ::) ::) ::) ::) ::) ;D
how much movement roughly would be acceptable?
RIP Paul Lovejoy
Webby the Bear
and presumably when we measure end float, this is what we're really testing? :)
RIP Paul Lovejoy
Quote from: Webby the Bear on 19 November 2013, 18:38:49....
Errr? Not sure really  :-\ There'll be limits quoted somewhere. It won't be that much because the thrust 'bearings' are only white metal  ..... like a main/big end.
Quote from: Webby the Bear on 19 November 2013, 18:39:20
yes  :y :y
Webby the Bear
got ya!!!! cheers andy. so basically just look at the end float tolerance and thats your thrust bearing test  :) :) :)
RIP Paul Lovejoy
Thrust bearings are often incorporated into one of the main bearing shells, i.e. the inside of the shell forms the main bearing, and it has an additional thrust surface on either end of the bearing which runs between 2 faces machined on the crankshaft.
Haynes manual gives maximum crank endfloat for the V6 as 0.05-0.15mm.
