Plastigauge - what's the point?
Started by Webby the Bear, 18 November 2013, 19:58:02
Quote from: Kevin Wood on 19 November 2013, 20:48:34
Thrust bearings are often incorporated into one of the main bearing shells, i.e. the inside of the shell forms the main bearing, and it has an additional thrust surface on either end of the bearing which runs between 2 faces machined on the crankshaft.
Haynes manual gives maximum crank endfloat for the V6 as 0.05-0.15mm.
Bit like this:
Thrust bearing top left, regular bearings are the rest..
Good pictures of how they'd fit in here: http://www.ffcars.com/forums/2475069-post34.html
End measuring endfloat the 'right' way: http://www.ffcars.com/forums/2485122-post36.html
Ahh, was just thinking some pictures would help. :y
Quote from: Kevin Wood on 19 November 2013, 21:35:26
I nearly went out and took a photo of the bottom of my 428 .. then remembered how heavy it is with the heads bolted on and just lifted some from a favourite thread instead ;D
Webby the Bear
 ;D
got ya lads.
this video was pretty useful too. but I like to discuss things on here cos not everything on youtube is accurate  :-X ::) ;D
http://www.youtube.com/watch?v=Vdl7texNgBk
RIP Paul Lovejoy
