Pages: 1 [2] 3  All   Go Down
Author Topic: 30XE Locking tool loan  (Read 12187 times)
symes
  • oxford
    • R reg 940 volvo
Re: 30XE Locking tool loan
« Reply #15 on: 20 November 2013, 21:54:54 »
This might do it.
http://www.buypartsby.co.uk/details/VAUXHALL/OMEGA/3.0/1999/__/54/CT990K1/timing-belt-kit/
I think I'm right in saying V6 water pump doesn't have to be changed with cambelt if it's OK because it's aux belt driven.
:y :y
Yes, i know, but this is a 209K mile engine with no known replacement so far, so if I'm in there it seems sensible to me to bite the bullet.
There is known to be a squeal and metal 'swarf' on one of the rollers (aux belt i hope!), so I'd like that fixed too.
belt tensoner pulley or alternator bearing-but you probably know that anyway and if doing cam belt-yes you would find it easier to do pump then--TBH I would do pump too  :y
LC0112G
« Reply #16 on: 25 November 2013, 21:27:02 »
Ok - I'll keep this thread running as things progress (or regress!). Thanks for all the kind offers of help, and I've now managed to secure the loan of a timing kit from someone known to you all who shall remain nameless unless they want to grass themselves up. ;D
This afternoon i watched the DVD for the second time to gen up on ways to screw the job up. Shocking - absolutely dreadfull. Those legs are a disgrace :D
Anyway tonight started out with me deciding to do an spark plug change and investigation into my oil leak. This involved plenium off, and before I knew where I was, I'd stripped it down and was looking at a cam belt. I guess I'm now at the event horizon - the point of no return. I didn't remove the belt because the cam lock kit isn't with me yet, but what I've found so far is...
1) The rubber antivibration mount on the middle of the air injection rail is FUBAR.
2) The one way valve in the air injection rail is FUBAR
3) A previous gorrilla has beaten me to the opportunity of snapping off all the clips on the wiring loom plastic channel - it was held together with tie wraps.
4) The squeaky bearing appears to be the secondary belt tensioner pulley.
5) The Aux belt is aftermarket, and on the verge of becoming an ex-aux belt. It's cracked and wasn't tight enough for me to undo the A/C compressor? PAS pump? screws without locking it.
6) the Crank AV damper looks OK - well it's in one piece at least.
7) I need a T-20 hex drive - turning the crank with a T-20 hand spanner is painful when it slips off.
So before I go and get raped by the dealer tomorrow, does anyone have a known good second hand aux belt tensioner, an air injection one way valve, or the plastic cable trunking? I can pay by Paypal and/or Direct bank transfer.
Cheers
Malcolm
« Reply #17 on: 25 November 2013, 21:32:00 »
Sorry, my half decent selection of spares (and tools) were lost in the fire  :'(
For tensioner, dealer does supply the pulley on its own for about £25, but will deny it in favour of a £50 tensioner.
Sometimes, the old one can be recovered by greasing up the bearings, depends how far its gone.
« Reply #18 on: 25 November 2013, 22:02:56 »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #19 on: 25 November 2013, 22:06:45 »
Cheers
Malcolm
should have both of the above, let me look in my den in the morning.  :y
edit, may have a good pulley aswell now im thinking about it.
LC0112G
« Reply #20 on: 25 November 2013, 22:39:20 »
Sorry to hear about your misfortune
Thanks - Forewarned is forarmed. EPC says the pully is 9157962, complete tensioner is 90528760.
Yeah, but it's the swarf that worries me.
Was going to edit my original post to add part numbers from EPC, but I can't - something to do with exceeding the time allowed! So far on my shopping list I have...
9157962 - Auxillary belt tensioner pully
91126388 - Auxillary drive belt  (ident FX)
90469782 - Secondary air injection one way valve
90160351 - Secondary air injection anti-vibration mount
9281374 - Secondary air injection anti-vibration mount
90543277 - Water Pump
Plus a cambelt kit which isn't listed in my copy of EPC (EPC2000).
« Reply #21 on: 25 November 2013, 22:50:13 »
My aux tensioner pulley became noisy due to a noisy bearing two years ago. I repacked it with grease and all was well.
However, it let go catastrophically with no warning last Friday night,taking the belt with it. I suppose an extended life of two years cant be grumbled at,but the fact it didn't start whining again before disintegrating now worries me a bit.
Why the hell are they made from plastic anyway ? Seems silly to me.
If you don't get sorted with the parts from offers already made, I may have some of them among my spares,so give me a shout if you get stuck. :y
LC0112G
« Reply #22 on: 28 November 2013, 23:11:57 »
Another 3 hours spent tonight. I set the notebook up in the workshop and went through the re-assembly step by step. Some observations...
Comment #1 : The latest GM cam-belts don't have any markings on them. No direction of rotation, and no alignment marks for the crank and cam centers, nothing. This scared the willeys out of me. I think I've got it right, but I won't know till I try to start it (hopefully tomorrow)
Comment #2 : It took me at least 10 goes to get the timing lined up right - or what I think is right.
Comment #3 : My auxillary belt tensioner doesn't have the bracket for the electrical cable ducting to clip into. Probably discarded by the last gorilla to work on it. And The bolts are cap-heads, not torx.
Comment #4 : There is a cheat in the DVD. Somewhere around 8 minutes into the re-assembly, the sheared off rubber AV mount for the secondary air injecton disapears from the bracket it's mounted in. I sat for a good 15 minutes waiting for mine to disappear, but it's still there  >:(
I abandoned work at 9pm. Just got to put the bagpipes and plenium back on, so should know tomorrow how much of a botch I've made of it.
The Red Baron
« Reply #23 on: 28 November 2013, 23:23:58 »
as long as you have used the locking kit & got it set up correctly then you should be ok. i always rotate & re-check, then again several times to be sure.  :y
« Reply #24 on: 29 November 2013, 16:56:33 »
Yeah, Gm belts haven't had markings for a few years, and some of the Conti and Gates ones are wrong. Ignore markings, go by the locking/timing kit :y
« Reply #25 on: 29 November 2013, 16:57:10 »
If that refers to cable tray, then correct bolts are cap heads ;)
« Reply #26 on: 29 November 2013, 16:57:23 »
Oh, and WRT to the DVD, omebody should apologise for those legs of Fuse18/Marks DTM Calib ;D
« Reply #27 on: 30 November 2013, 00:45:52 »
.. And think yourself lucky it doesn't have a Loo-Knee sound track. ::)
The Red Baron
« Reply #28 on: 30 November 2013, 14:24:10 »
you dont meen rick ghastly per chance.  :D
LC0112G
« Reply #29 on: 30 November 2013, 19:47:59 »
All Together now....
Never gonna give you up, never gonna let you down, never gonna turn around and desert you........
You really really don't want to explore my musical tastes, as those of you from 'the other place' will know ;)
I was trying to work out the film location - sounds like Tiger Moths in several plaves on the DVD, so somewhere in the Duxford or Shuttleworth area?
Anyway, back on topic started it up yesterday evening. A few strange noises at first, but soon settled down. Sounds more roarty than I remember, possible passenger side exhaust manifold problems?, but then again i haven't spent much timemwith my head under the bonnet, so perhaps i'm hearing things that are normal.
Haven't had a chance to drive it yet due to other work I've commenced and not completed - hopefully tomorrow.
Pages: 1 [2] 3  All   Go Up
