Author Topic: Omega thermostat part number.  (Read 4166 times)
Bikerdon
  • Glasgow
    • Vauxhall Omega 2.6 V6 Est
« on: 20 November 2013, 11:36:07 »
Hi, can anyone confirm the correct part number for the thermostat assembly for my 2001, Y plate Omega 2.6. I think it is 90502201 but just wanted to be sure first. Thanks. :)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Omega thermostat part number.
« Reply #1 on: 20 November 2013, 12:00:41 »
The one of my 2003 3.2 petrol saloon is 24420652, I have just changed mine and the old one is in my hand as I write. It's the number on the Autovox website for most of the V6 Omegas, but not on the one they sent me! . Theirs fitted all right and seems to work. Good luck with the B-bolt, and with getting the transfer pipe out of the old thermosat.
« Reply #2 on: 20 November 2013, 12:17:27 »
This part number is the correct one...
http://www.ebay.co.uk/itm/200914781107?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Perfect fit, correct thickness, no nonsense.
Bikerdon
  • Glasgow
« Reply #3 on: 20 November 2013, 12:23:26 »
A new genuine transfer pipe is on its way to me now just to be prepared, so no worries there, B bolt might be fun, but I served my time as an engineer when I left school so can usually deal with most problems, I've always done all my own mechanical maintenance/repairs, etc myself including complete engine rebuilds on cars and motorcycles, so It shouldn't beat me. Strange how many different part numbers come up when searching for the stat housing. :)
« Last Edit: 20 November 2013, 12:27:32 by Bikerdon »
« Reply #4 on: 20 November 2013, 12:30:37 »
Search the part numbers from here...
http://oemcats.com/
Then rummage around ebay.co.uk, ebay.de and ebay.com to locate the relevant part :y
Just to add, the likes of AutoVaux rarely sell genuine parts, regardless of their blurb :-\
Bikerdon
  • Glasgow
« Reply #5 on: 20 November 2013, 22:57:47 »
thanks for the info on part numbers, the main difference appears to be the thickness of the base of the stat housing where the mounting bolts go through. Now, I really dont want to start stripping the car until I have all the parts, so its a bit awkward as I cant see any way of visually confirming which one is fitted just now without pulling it apart.
« Reply #6 on: 20 November 2013, 23:24:33 »
Someone else might be able to confirm, but I believe the DBW V6s have the thicker base :-\
Bikerdon
  • Glasgow
« Reply #7 on: 20 November 2013, 23:36:43 »
Well mine is a Drive By Wire, so hopefully that might narrow it down. engine no in my service booklet is Y26SE-08565211 if that helps.
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #8 on: 21 November 2013, 16:05:06 »
I did the thermostat on my 2.6, 2001 earlier this year and used the dealer for parts (new seals too etc). The part number on the invoice is 90502201. The replacement unit was the same and fitted with no issues.
« Reply #9 on: 21 November 2013, 16:12:12 »
I did the thermostat  .... earlier this year and used the dealer for parts (new seals too etc). ... The replacement unit was the same and fitted with no issues.
Likewise on my 3.0 MFL  :y
Bikerdon
  • Glasgow
« Reply #10 on: 21 November 2013, 19:49:59 »
Andy B and allen25, can you remember if the base of the stat where the bolts go through was the thick or thin type. Thanks bikerdon. :)
« Reply #11 on: 21 November 2013, 19:58:10 »
The key part being 'dealer supplied' :y the part number discrepancies may well be engine or chassis number related :-\
The key thing being to identify the part number of what was fitted new to your car, and replacing accordingly :y
« Reply #12 on: 21 November 2013, 20:51:49 »
Having only done one 'stat I've nothing to compare it with ......  ;) but I think it was around 1/4" thick
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #13 on: 21 November 2013, 22:55:44 »
I can't actually remember but I'm sure I used the same bolts to re-fit. As a guess though and please don't totally rely on it, the base was substantial and probably 5mm thick. If it is engine and chassis related it could be worth checking the part number with the Dealer before deciding where to purchase?
« Reply #14 on: 21 November 2013, 23:15:26 »
..... but I'm sure I used the same bolts to re-fit.  ....
Same here
Page created in 0.029 seconds with 16 queries.
