It was worth it
Started by tooleater, 22 November 2013, 18:10:54
tooleater
V6 Thermostat change, after much F-------- + blinding got it done :o even managed to some how magically to lose the plug and its little loom for the Idle speed adjuster under Plenum >:( that engine bay ???  breath, hold and Exxxhale. Thank God I took off the Plenum again a further check with Mr Led Lenser revealed a Leaf sitting on the valves and yes I used kitchen roll at all stages. but credit to engine,only 11 of the 12 sandwich plate bolts are torqued, 1 is knackered and it still runs sweet :y
chrisgixer
Is it worth it?
What is this Blasphemy! ;)
tooleater
Your right I should be stoned ;)
MR MISTER
Quote from: tooleater on 22 November 2013, 18:33:45
You'll be wanting some weed then. PM sent.
tooleater
you d need it have encountering the B Bolt ;D
Webby the Bear
RIP Paul Lovejoy
