MPG
Started by Mr.OmegaMan, 24 November 2013, 18:43:51
Mr.OmegaMan
I've noticed recently (going by the trip computer) that my avarage MPG has gone down from 26-28mpg to around 20-23mpg, Going the same route roughly 27 miles each way, Nothing different in the driving patern apart from having the hid lights on and heated seat on.. I have reset the computer before setting off and before heading back... Do these really use that much or could it be the cold weather even or something else  ???
MR MISTER
Quote from: Mr.OmegaMan on 24 November 2013, 18:43:51
Have you changed you air filter?  ;D
Mr.OmegaMan
Quote from: STEMO on 24 November 2013, 18:44:36
Yep, Had a service Mid June 2013 along with oil, spark plugs etc.. GM parts. It had a fuel filter just over a month ago.
MR MISTER
Quote from: Mr.OmegaMan on 24 November 2013, 18:48:21
That'll be it then. Read Opti's thread. ::)
Mr.OmegaMan
Quote from: STEMO on 24 November 2013, 18:49:37
So I need a dirty air filter  ;D
In all fairness it's been fine on MPG till the clocks went back and it started to get cold. Even hit 31mpg at one point. That's if the trip computer can be trusted.
PAULCDX
Could it be down the fact the car is working harder with heating on, lights on, engine colder etc ?  ;)
Just a guess but what do I know?  :D  ;D
MR MISTER
Quote from: Tall Paul on 24 November 2013, 18:55:40
More than most on here by the sound of things, Paul ;D
martin42
What is running temperature like? Normal or way below?
You'd be surprised what cold weather, heated seats ect can do to fuel economy
Even with a new thermostat, mine is barely doing 23mpg ::)
Mr.OmegaMan
Must be the cold dark weather then, Running temperature is around 85c/90c.
Quote from: Mr.OmegaMan on 24 November 2013, 18:53:40
In all fairness it's been fine on MPG till the clocks went back....
Don't worry about it, as it'll be fine in a few weeks when the clocks go forward again!  :)
blackviper90210
I'm averaging 25.8mpg according the computer. Not bad considering how I drive  ;D ;D ;D
AKA - Mr Bracket
2boxerdogs
My 2.6 has always returned 30mpg on my daily commute , however for the first time  last week I have started using the heated  seat & also changed the air filter in June.. My consumption is now 28mpg, so must be the combination of both.
Dan282
It doesn't take much for it to drop or increase. Mines current on 29.4 mpg but I've done about 5 miles in the last month ;D
