Author Topic: LPG Doughnut Tank  (Read 5106 times)
Re: LPG Doughnut Tank
« Reply #15 on: 31 May 2008, 21:44:01 »
You just KNOW if one bulb goes, the others will follow shortly !
I had BOTH single filament tail lamps go on my car last week end. They must've both blown together as I only had the warning message once.
« Reply #16 on: 31 May 2008, 21:45:09 »
They are also much more pricey!!!! I wasn't sure on the mounting of a vertical torroidal as I was under the impression they had to be attached to a metal frame.  :-? :-? :-/ :-/ :question :question
Nice to see you around again Marie... I hope things are settling down for you!  :y :y :y :y
« Reply #17 on: 31 May 2008, 21:50:46 »
whats the eBay kit people here have used? might be worth dropping the guy who sells them and find out a price, see how much more it is.
Martin_1962
« Reply #18 on: 31 May 2008, 21:55:16 »
LPG was 69p a litre at the local BP today, petrol was £1,19.
Even with my super low millage i could get it back in a year.
I spend about £130 a month on fuel (2 tanks)
So that works out at £1,560 a year in fuel.
£700 for the DIY kit?
Less than 12 months use and its paid for itself
I filled up at 48p a litre today :y
HolyCount
« Reply #19 on: 31 May 2008, 21:55:22 »
There's the number of the guy in the Who Knows GNU thread -- will have a peek --if no-one beats me to it .......
Martin_1962
« Reply #20 on: 31 May 2008, 21:56:05 »
with the tank in place its easier to remove the light cluster complete,however you only have to loosen the strap holding the tank down and tilt it to one side to gain access.
Cheers for that.
Its all markey marks fault, he got me thinking i would only do it to an estate... but that got me thinking about doughnut tanks again.
As i don't want to loose boot space or give up my sub!  :D
Do you carry TB4 around then ;D
« Reply #21 on: 31 May 2008, 21:59:17 »
Look at this listing... http://cgi.ebay.co.uk/MOTOGAS-AC-6-CYLINDER-LPG-INJECTION-GAS-CONVERSION-KIT_W0Q...
I know it's ended and has the wrong number of cylinders but he's the guy... Don't forget to mention OOF!!!  :y :y
« Reply #22 on: 31 May 2008, 22:03:53 »
Incomplete link?
Says timing out....
HolyCount
« Reply #23 on: 31 May 2008, 22:03:55 »
Speak to Jeremy on 07830302988. Thats the guy who sells on eBay
« Reply #24 on: 31 May 2008, 22:05:16 »
Cheers  :y
HolyCount
« Reply #25 on: 31 May 2008, 22:05:43 »
This is the guy -- nothing listed for sale at the mo tho:
http://myworld.ebay.co.uk/u-fit-lpg
« Reply #26 on: 31 May 2008, 22:07:36 »
Incomplete link?
Says timing out....
:-[ :-[ :-[ :-[ :-[ Note to self.... Check links before trying to be helpful!!  ::) ::) ::)
HolyCount
« Reply #27 on: 31 May 2008, 22:09:06 »
Can't be at fault for trying to be helpful Lazydocker  :y
« Reply #28 on: 31 May 2008, 22:23:27 »
E-mailed  :y
« Reply #29 on: 31 May 2008, 22:30:26 »
Remember to mention OOF.
Pages: 1 [2] 3 4  All   Go Up
