Author Topic: Terraclean?  (Read 3908 times)
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
Terraclean?
« on: 25 November 2013, 17:17:46 »
I've never been a fan of engine additives for claimed miracle cures.  After watching an episode of wheeler dealers I saw the terraclean discarbonising treatment advert with Ed China.
I've read through their website and wondered what other members make of it?
I'm in 2 minds if it will actually be a benefit or if it's just another glossy advert for something that isn't necessary.
Dan
Re: Terraclean?
« Reply #1 on: 25 November 2013, 17:47:57 »
I think Omegaman on here has had that done  ;)
Keith ABS
  • Maldon Essex
Re: Terraclean?
« Reply #2 on: 25 November 2013, 19:54:27 »
  I spoke to them at this years NEC as several ABS LC owners are thinking of getting it done. It is not an addative but a special fuel that is put in in place of your normal fuel for the "clean"
Keith B
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Terraclean?
« Reply #3 on: 25 November 2013, 20:40:44 »
It's a pure fuel they run for a while to clean crap from the engine.  Sounds very good, cost is reasonable - IF it makes a difference.
pauls
  • By the sea minehead
    • Bmw x3
Re: Terraclean?
« Reply #4 on: 25 November 2013, 20:56:16 »
A mate has a jagx350 petrol with 197k he had it done a couple of months ago and said it works a treat, says he feels it in the power delivery most.
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
Re: Terraclean?
« Reply #5 on: 25 November 2013, 21:21:33 »
What sort of cost is it as it does sound like it works.
pauls
    • Bmw x3
Re: Terraclean?
« Reply #6 on: 25 November 2013, 22:27:02 »
I think he said it was £100
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Terraclean?
« Reply #7 on: 25 November 2013, 23:03:09 »
Cataclean the stuff I've used twice now in the 3.2 seems to idle a little better and mpg was a little more.. No idea on emissions haven't had an MOT done yet since I starred using Cataclean every three months. Will try to remember the readout when the MOT is due around May..
Re: Terraclean?
« Reply #8 on: 25 November 2013, 23:25:31 »
At a 100 notes a go?  :o :o :o
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Terraclean?
« Reply #9 on: 25 November 2013, 23:56:47 »
Where did you pull that figure from  :o ;D
Na Cataclean is just over a tenner  :y
Buy mine here..
Cataclean 475ml Engine and Catalytic Converter Cleaning Treatment
http://amazon.co.uk/dp/B002BVXM92
Re: Terraclean?
« Reply #10 on: 26 November 2013, 01:18:39 »
Buy mine here..
Doh!! Thought you were getting it Terracleaned every 3 months for 100 notes, didn't notice you said Cataclean....  :-[  ::)  ;D
Re: Terraclean?
« Reply #11 on: 26 November 2013, 08:51:20 »
Far from convinced here, any benefits would be short lived as even if it did remove (what little) carbon is present  then it would soon return. If it was a shitty old yank engine from the 80's and 90's then yes, could have more of an impact.
You would be better using the cash to get your injectors cleaned.
Dan282
  • Stoke on trent
    • 2001 3.2 Elite
Re: Terraclean?
« Reply #12 on: 26 November 2013, 09:16:04 »
That's the other thing I was thinking off. Seems a few people have opted for that instead of terraclean.
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: Terraclean?
« Reply #13 on: 26 November 2013, 10:18:41 »
What's the best way to clean the injectors then?   My emissions on the MOT 3 weeks ago showed them either hardly registering or bang in the middle of the range.
In my case, is it best to leave things alone as they are not "broken" or do it anyway?  :-\
AKA - Mr Bracket
Re: Terraclean?
« Reply #14 on: 26 November 2013, 11:21:31 »
Take them off the car, check flow rate and pattern, ultrasonic cleaning bath then check flow rate and pattern again. This way you know they are performing to spec, and know if you've made any difference. Any that don't perform afterwards you can replace.
Squirting fluid in on the engine as with Terraclean is only going to clean the injectors anyway, as a modern engine won't accumulate any significant carbon deposits, as said, and the fluid doesn't go anywhere other than the fuel rail and injectors, so it can't clean anything else.
For the cost of a Terraclean you can get a set of injectors cleaned properly and have change for a night out. No brainer. Not that injectors get that badly clogged unless they've sat in a breaker's yard for years, IME.
