Author Topic: Headlight  (Read 2203 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Headlight
« on: 02 December 2013, 16:41:30 »
Can anybody give me the part no. for a 2.6 v6 2003 saloon. passenger side headlight. Any advice on where to obtain a replacement for mine which is showing damp on the lens I assume a seal has gone can they be fixed.
Re: Headlight
« Reply #1 on: 02 December 2013, 18:14:59 »
Are all the covers on the back in place?
Whip it off the car, remove the covers, overnight in the airing cupboard then refit covers and fit back to the car :y
Double check the seal on the indicator bulb holder as well :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Headlight
« Reply #2 on: 02 December 2013, 19:15:21 »
Thanks never taken the headlight out are there any problems involved.
Re: Headlight
« Reply #3 on: 02 December 2013, 19:17:05 »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Headlight
« Reply #4 on: 03 December 2013, 20:14:24 »
Thanks for that I assume that a standard 2003 v6 doesnt have HID Xenons is this correct. Are they an after fit or standard on certain models, What is the risks with the HID Zenons.
Re: Headlight
« Reply #5 on: 03 December 2013, 20:18:46 »
Standard on CDX and above, optional on rest in 2003 :y
Have a look through the maintenance section, sure there's a how to in there :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Headlight
« Reply #6 on: 04 December 2013, 09:38:46 »
Thanks for the info so as mine is CD it probably does not have Zenon HID Will see when I remove it.
Was interested to know why the battery needs disconnecting when removing Zenons, :y
Re: Headlight
« Reply #7 on: 04 December 2013, 10:16:18 »
Correct.
Not necessary but it`s a safeguard as the ballast produces heavy voltage
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Headlight
« Reply #8 on: 04 December 2013, 12:27:16 »
Right thanks RobG Must make sure what I have fitted then.
Re: Headlight
« Reply #9 on: 04 December 2013, 13:01:50 »
Assuming no one has previously been meddling, no headlight washers = no xenons :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Headlight
« Reply #10 on: 04 December 2013, 19:47:56 »
Thanks what is Spec of bulbs is used in my 2003 V6 cd saloon headlights  The handbook doesnt give the specification Anybody have any feedback on headlight units from ACE PARTS advertising on flebay very cheap compared with GM.
