Author Topic: Which Compressor ?  (Read 1806 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Which Compressor ?
« on: 03 December 2013, 22:00:25 »
Hi all...
Having just learnt that I shall be receiving a large cash Christmas present this year, I am going to get a Compressor. I used to be in the spraying game for 20 years, but that was 20 years ago, so with age, knowledge is diminishing.  ;)
I know you only get what you pay for, and am looking at around £100. Basically, just to run a few air tools, but really to enable me to respray small panels on the Omega if required.
Does anyone have any experience in this area...what size tank do I need, and what pressure.
Could kick myself, as I gave away my other two compressors a while back, one used to supply air for a garage :(
TIA ;)
Re: Which Compressor ?
« Reply #1 on: 03 December 2013, 22:08:05 »
200 litre ideal .. 100 litre minimum..  dual head if budget permits..  and compressors must be kept in a close area where dust cant enter easily and away from all polishes, pastes and other chemicals..  once they get dirty will ruin all after jobs..
also filters must be periodically cleaned and renewed if necessary
ps: dont look for second hand , they are mostly too dirty for proper paint job
pps: water must be also checked and removed frequently, avoid painting in rainy weather
« Last Edit: 03 December 2013, 22:12:12 by cem »
« Reply #2 on: 03 December 2013, 22:20:16 »
I've got a small compressor from this range:
http://www.machinemart.co.uk/shop/range/details/airmaster-tiger-turbo-air-compressors-2/path/airmaster-2
I think mine is the 8/44, which would have come well within your £100 budget when I bought. You still might get something similar in that budget on a VAT free day. I suppose an oil-free one would be best for spraying? Never tried it myself, though
As you can see, you need to spend more to get within Cem's recommended spec. A 25L model will need regular breaks to catch its' breath, and the motors are far from continuously rated but I find mine OK for light use of air tools.
« Reply #3 on: 03 December 2013, 22:20:33 »
if you use small 0.8 or 0.5 micron spray guns, it will require less air volume per minute..  but still you will have to stop many times when painting a single small panel..
« Reply #4 on: 03 December 2013, 22:21:35 »
yep.. I have checked UK prices, they are horrendously expensive!  also electric models would be better of course.. but not sure you can find them at high volumes
« Reply #5 on: 03 December 2013, 22:23:38 »
Prices on that sort of kit have soared in the last couple of years. I suspect the boats from China are in short supply.
« Reply #6 on: 03 December 2013, 22:36:12 »
I have learned that compressor is  a very very critical item for paint jobs.. in the hardest way ;D
« Reply #7 on: 03 December 2013, 22:39:00 »
there are also air cleaner/de-humidifiers for paint jobs but the list very quickly goes above budget.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #8 on: 04 December 2013, 15:44:15 »
There's a wolf one that's been advertised in the national press for £199,looks good.
Hoof'land storeman.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #9 on: 04 December 2013, 16:43:53 »
Thanks for replies. :y
I could stretch to £200. I have £300 total, but I want to put new guts in this computer also.
Once I suss out how much a motherboard, ram and cpu will cost, plus possibly a new card, I'll know how much I can afford, give or take a quid or two :)
Taxi_Driver
« Reply #10 on: 04 December 2013, 18:09:01 »
That's just blown the £300 then  :)
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #11 on: 04 December 2013, 19:15:16 »
Naw...I'll get the upgrade bits for less than that....
Just had my winter fuel payment through....that's another £100 :y :y
biggriffin
« Reply #12 on: 04 December 2013, 19:25:03 »
cant resist.. Be another pensioner on here when they get there winter bill in moaning that they cant afford to pay to heat there home? Why? Because they spent the money on something else.
gets off soapbox
Hoof'land storeman.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #13 on: 05 December 2013, 00:41:25 »
gets off soapbox
 ;D ;D ;D ;D ;D ;D I knew someone would bite :y
