Author Topic: Best way to set up compression test  (Read 1135 times)
Vauxhalloofer
  • South East
    • Cdx 2.2
« on: 04 December 2013, 00:27:16 »
Hi peeps , Want to do compression test due to excessive oil use and smoke on start up, its a 2.2 2001.Would just pulling crank sensor and having spark pack connector disconnected be ok or its it best to leave crank sensor connected and pull fuel pump relay, if so which relay.Has always used oil, noticed when i did head gasket that some valves had been changed.Thanks 8)
Re: Best way to set up compression test
« Reply #1 on: 04 December 2013, 00:29:23 »
Just pull fuse 18 under the steering column. Coil pack will be disconnected when you remove it :y
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #2 on: 04 December 2013, 00:30:36 »
Nice one cheers
