Author Topic: 2.5 petrol manual won't start - no fuel at engine  (Read 5789 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 04 December 2013, 16:21:49 »
X84GNB 2000 2.5 petrol manual estate
Engine cranks well but does not start. My first thought was failed crank sensor. Then I loosened a fuel pipe to check fuel feed when cranking, and found there was none. There is fuel in the tank.
I know there is a relay, but do  not know where. Is there a fuse? Perhaps the pump has failed.
Please advise procedure to isolate fault.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: 2.5 petrol manual won't start - no fuel at engine
« Reply #1 on: 04 December 2013, 16:31:14 »
fuse 18, 20amp. in dash.  ;)
« Reply #2 on: 04 December 2013, 17:05:47 »
Give the tank a kick from under the bumper whilst a willing assistant cranks it :y
Pumps stick when they start to fail...
Other thing is to swap the two purple relays in the engine bay fuse box with ones from a working car :y
« Reply #3 on: 04 December 2013, 17:22:55 »
Iirc the fuel pump wont pump fuel if the crank sensor has died.
« Reply #4 on: 04 December 2013, 18:04:58 »
It runs briefly at position 2 to prime the fuel rail. If the engine fires, then it starts and runs permanently...
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 04 December 2013, 20:31:35 »
Thanks Gentlemen. I have checked Fuse 18, it's OK. I have pulled out the two purple relays, but could not get both purple relays out of R706FHD, a 2.0 petrol. I got one out, I have more at work so will bring them home tomorrow.
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 04 December 2013, 20:57:23 »
dont know if important or not but check the terminals are the same on the relays you exchange---my miggy had 1 more pin on its relay than on the relay i got from another miggy---wierd
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 04 December 2013, 22:36:59 »
I always believed the fuel pump operated at low rpm as long as the starter was cranking, but not with just the ignition switched. This presumably was a safety measure to avoid fuel fires after accidents. I did expect fuel to feed while I cranked the starter. It did not happen.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 04 December 2013, 22:42:38 »
Could this be linked to crank sensor.... in college we observed a mondeo that had a faulty crank sensor. we checked for spark during cranking and there was no spark. this is apparently indicative of a failed crank sensor. if it has no spark is something somewhere cutting the fuel off as precaution??? just a thought :)
RIP Paul Lovejoy
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 05 December 2013, 07:40:17 »
As said above, I see the wisdom of cutting off fuel supply below, say, 200rpm, to minimise fire risk. But engine will never start unless fuel pressure is raised while cranking to start engine, therefore pump relay is engaged with starter relay.
Today I shall substitute good violet relays for the two in X84GNB. IF no change, I suppose i should next check volts and action at the fuel pump.
I have had five non starter Omegas, all caused by failed crank sensors. I did not note down that I had checked fuel feed on those occasions, but I think I would have.
Does anyone know which colour wires to fuel pump and gauge socket are power to the pump?
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #10 on: 05 December 2013, 08:31:33 »
I think pump feed is blue/red (or is it red/blue)?
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
philhoward
  • Staffs
« Reply #11 on: 05 December 2013, 09:28:39 »
..and I don't recall a priming pulse either (had fun trying to get my X30XE running from empty and a dead crank sensor); manually jumpered the fuel pump relay to get fuel up to the rail.
« Reply #12 on: 05 December 2013, 09:49:27 »
If no joy with the relays, give the tank a kick about a foot in from the towing eye whilst some one else cranks it :y
If it fires, the pump is on its way out...
Quicker and easier than testing for a wiring fault... might as well start with the easy stuff :y
« Reply #13 on: 05 December 2013, 09:58:21 »
In all the years I have worked on them, I have never seen a priming pulse on the 2.5/3.0, the fuel relay only pulls in when the crank shaft is seen to turn.
Reality is that the fuel pressure remains for days and even weeks after the engine is turned off (unless you have a leaky injector) so no need for it.
Hence crank sensor is a favourite.
An option is to pop the top off the fuel pump relay and manualy actuate the relay if you must, do you have a spark?
philhoward
  • Staffs
« Reply #14 on: 05 December 2013, 10:40:50 »
In my case I'm not using the Omega pump (or tank) - one from a Ford Focus of unknown heritage and I think Fords DO have a priming pulse..perhaps as their pump setup isn't as good?
Not helping the OP's problem though ;D
Page created in 0.033 seconds with 16 queries.
