Depressing MOT failure.
Started by albitz, 04 December 2013, 23:07:58
Not the Omega, the Merc 190D
Failed on leaking metal fuel pipe which looks a pita to change, particularily at this time of year with no garage.
Also failed on seized balljoints, a common problem with them. No big deal I thought,I can change balljoints with my eyes closed.
Not these ones I cant. Standard method is to acquire expensive MB tools to remove and press them back in, in situ. Other method is to remove the wishbones and press them in/ out with a big press. Problem is the front springs cant be compressed with normal compressors, they need a special Merc type of compressor which are at least £100.
What to do ? I hate cars sometimes. ::)
Find a garage still offering scrappage and buy summat else ::)
kevinp58
Thats why mercs have the worst depreciation. when brought new as most things need special tools and diagnostics.  >:(
That would be giving up. I don't like giving up. ;)...........it will be worth it once its done.......I hope. ;D
Quote from: kevinp58 on 04 December 2013, 23:13:16
No diagnostics on this one.The only thing electrical is the lights.  ;D
Its 23 years old. :)
Did I mention my Merc Albs?  :D  ;D
jonny2112
Sorry to hear that mate, but you'll sort it out  :y
kevinp58
Quote from: Albitz on 04 December 2013, 23:16:02
You are lucky that you still have the front suspension still attached to the car then.  ;D
Nah, at that age of Merc its not such an issue, its mid 90s and the 00's where they rot faster than an SD1
Quote from: Fuse18 on 05 December 2013, 08:53:26
You're not wrong there, mine's dissolving as I type....  :'(
When I sell it, I'll advertise it as an authentic late 1990's Mercedes Benz complete with an ongoing self modification feature!  :D  ;)
Fix it , it will pay you back in the fuel you wont use  :D Having no garage is a pita though  :(
omegod
Sad it turned out to have some issues, sure someone on the 190 forum has the spring tools. Failing that send it down to me as I liked the look of it originally.  ;)
Quote from: Sir Tigger on 05 December 2013, 10:10:23
I thought that all Merc's had a 'built from granite' reputation.
They did until the mid 90,s  ;)
