Author Topic: 2.2 compression values.  (Read 1659 times)
Vauxhalloofer
  • South East
    • Cdx 2.2
« on: 05 December 2013, 15:21:31 »
Hi peeps , does anybody know what the dry compression values should be on a 2.2 2001 manual ,Z22XE.Thanks.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: 2.2 compression values.
« Reply #1 on: 05 December 2013, 15:22:45 »
i dont. but add compression ratio together e.g. 11:1 = 11 + 1
then
12 X 14.7 (atmospheric pressure).
theres your answer :)
RIP Paul Lovejoy
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #2 on: 05 December 2013, 15:37:52 »
got  values of 100 psi on all 4 lol with throttle closed.
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #3 on: 05 December 2013, 15:40:59 »
Need to get compression readings with throttle open - otherwise not enough air gets through to compress to give the reading.
If it's not in a manual somewhere, I'd expect 175-200psi each pot; no more than 10% difference across the board; ideally less than 5%.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #4 on: 05 December 2013, 15:43:27 »
Thought that didnt sound right will retest it.
« Reply #5 on: 05 December 2013, 15:50:11 »
Yes throttle open, the key thing is that they are all similar (as you never loose all four pots at once in the same way)
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #6 on: 05 December 2013, 16:08:01 »
Did notice all four plugs had oil all over them and some on the top.Have done the cam cover gasket as well. Its loosing oil i get smoke a bit for say 7 secs on start up and the exhaust has oil around it.  ???
« Reply #7 on: 05 December 2013, 16:40:05 »
Valve stem seals  :-\
Vauxhalloofer
  • South East
    • Cdx 2.2
« Reply #8 on: 05 December 2013, 16:48:27 »
Think you are right, as when i did the headgasket i noticed that 4 valves had been changed.Didnt send it off to be checked as didnt have the money at the time.So swapping the cylinder head out would sort this how do i know its not the pistons or rings.
« Reply #9 on: 05 December 2013, 19:12:17 »
Mine use to smoke on start up , cleared a bit when warm but still noticeable . On stripping down the head only one or two stem seals were seated but all worn  :( Replaced all the seals and no more smoke  :) Car never lacked power/performance of any notice while smoking so i never suspected rings .
