What Disco ?
Started by omega3000, 06 December 2013, 18:59:45
Been looking at this DICOVERY
Whats the opinion of you owner's on here , i know there are a few owners  :-\ Ive heard of rust issues so where are the points to look for and anything else  :)
the alarming man
#1
nothing wrong with a V8 if you have the money to run it....also the disco2 rots just as bad as the disco 1 the only thing with the 2 is more electrics to go wrong :y
with your problems getting into that one will be a problem as no side steps (£250 a set) and a 2 inch lift and so it may not get into a multi story
Quote from: the alarming man on 06 December 2013, 19:31:46
Was thinking LPG  ;) So disco 1 will be the best option . What about the diesel , are they renown for reliability ? Seen a lot of high mileage ones  :)
the alarming man
you will always get a petrol with lower milage...as for LPG check the prices for V8...disco 300 tdi is the best out of the two no problems apart from rust and...check for timing belt change on a diesel as V8 is chain driven
:o Ah never noticed that . What mpg do you get from your V8  :-\
Some useful info there anyway A/Man  :y
the alarming man
#5
driving it properly may be 15....with the V8 sound track about 9
he doesn't state it as had a lift but he as extended the hoses and terrafima shocks means it as had a lift as I have them on mine
look here....http://www.discoveryownersclub.org/
martin42
You cant have it,its over priced and not 99p  :y :y :y
the alarming man
not worth 99p....50p and a mars bar may be :y
Quote from: the alarming man on 06 December 2013, 19:42:09
Ta  :y
Quote from: The Mad mechanic on 06 December 2013, 19:43:40
But i mite get lpg for 99p  ;D
martin42
Cough-silver mv6-cough  :y :y
belldarr
Disco's are very prone to rot all over - areas particularly prone are the boot floor and the rear arches.  The sunroofs always leak (there are 2 of them) most of them will be sealed with sealant but still leak from the surround.
Have a look on Landyzone.co.uk and you will see a few of the common problems on there and there may be a buyers guide.
On that particular Disco in your link it looks like someone has modded it up to be a mud plugger so maybe view before you bid as it may have been battered round quarries and fields.  Wipers are not parked properly so could indicate electrical problems,
All that said - I have a 4.6 V8 Range Rover and love it to bits, bought it as a 3rd car but I always pick the keys up if popping into town, 12MPG is a bit frightening but that aside it's a great car.
Darren
the alarming man
yes my disco as 2 sunroofs and they never have leaked and they don't if the drain holes/pipes are kept clear... :y
belldarr
Quote from: the alarming man on 06 December 2013, 19:59:07
There's always one exception  ;D  Ok most sunroofs will leak  :y
Darren
Quote from: belldarr on 06 December 2013, 19:53:05
Darren
Thanks Darren , i just picked that one out in the link as an example . It looked clean but like you say it has been modded up a bit  ;)
