Author Topic: Rear of car seems low  (Read 6007 times)
« on: 07 December 2013, 20:43:38 »
KYB RX6226 springs fitted in 2011 by previous owner along with a cheap pair of rear shocks. No leaks from shocks, no busted coils. Height from road to arch is 65mm. When rear seats loaded the rear mudflaps scrape the surface over the slightest hump in the road and do the same when cornering left or right. Thinking rubbish shockers ??? ??? ???
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Rear of car seems low
« Reply #1 on: 07 December 2013, 20:55:48 »
Wrong type of springs fitted?
« Reply #3 on: 07 December 2013, 21:03:44 »
Knackered diff/subframe rear mounts :-\
Link doesn't specify saloon or estate :-\
« Last Edit: 07 December 2013, 21:06:16 by ex taxi al »
« Reply #4 on: 07 December 2013, 21:05:36 »
Checked three weeks ago @ MOT place, no discernible wear/play ???
« Reply #5 on: 07 December 2013, 21:08:50 »
Noticed that myself with KYB, on last set I used. They also rust really, really badly. Now use Boge
« Reply #6 on: 07 December 2013, 21:19:02 »
Linky or part number Mark?
« Reply #7 on: 07 December 2013, 21:34:38 »
Errrr think I got boge from allgerman, just searched & cannot find them. KYB rusted badly very quickly, forget where I got them from. But arrived boxed and branded KYB. They snapped inside 2 years!
3 years in maybe 4 now? Bogs ones look like new still!
« Reply #8 on: 07 December 2013, 21:48:52 »
Yeah, I binned a set of KYB's due to it sitting too low at the back after 2 or 3 years. And boy do they rust.
« Reply #9 on: 07 December 2013, 21:57:35 »
That really is low.  :o :o ::) ;D
« Reply #10 on: 07 December 2013, 21:59:54 »
Properly slammed ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 07 December 2013, 22:03:47 »
Properly slammed ;D
Some people pay good money to have their cars slammed low   8)
 ;D :y
« Reply #12 on: 07 December 2013, 23:13:13 »
Properly slammed ;D
Typo error ;D ;D ;D You know I meant 650mm :P :P ;D
chrisgixer
« Reply #13 on: 07 December 2013, 23:15:11 »
They are standard (NON self levelling) shocks for 3.2 saloon, so they are correct with standard non sl shocks. Failed shocks tend to give a bouncy uncontrolled spring rate. Bouncing the rear of the car by hand should give a push down, release, up down stop action to the rear, and be very hard work to keep the car bouncing by hand. Test in neutral with hand brake off, and chock the font wheels if its in a slope. If it keeps bouncing easily after you let go the shocks are buggered.
 Iirc the usual ride height for an elite 3.2 with sl is 675mm. While the shocks do hold the car up, I'd be surprised if the shocks account for 25mm of ride height. So I would also be checking for busted springs. Tbh.
chrisgixer
« Reply #14 on: 07 December 2013, 23:17:41 »
Just go add, you could just as easily wack some Sl shocks on. They will work just as well. But test the pump still works first I guess.
