Rattling door pins
Started by chrisgixer, 08 December 2013, 18:35:27
chrisgixer
It's not the door pin rattling in the door card, but the metal rod rattling in the door pin.
...or at least, that's another way they can rattle. Remove red tab, cover inner surface or red tab in double sided tape, re fit. Fixed.
ronnyd
I just slipped a smallish cable tie down beside the pin. A bit of a bodge but you cant see ,em and it did the trick. ;D
chrisgixer
Quote from: ronnyd on 09 December 2013, 16:59:22
I stuck a Velcro dot on the inside of the door card hole. It still rattles, so I assumed it had fallen off inside the door.
Upon removing the door card today, the Velcro is still there, so I obviously assumed wrong. Upon removing the door pin and rod from the lock mechanism, holding the rod with pin in my hand.... it STILL rattles!
So the pin can rattle in the door card hole. But the rod can also rattle within the door pin.
ronnyd
I reckon we are bound to get a few rattles on a 12 yr old car but it can still be a PITA. :P
i think someone put bluetak around the pin where rod meets door pin, they said it worked.
It's not a problem on my 2.2, occasionally here it on the 3.2, but on the passenger side
Need a superior p/f door  ;D :D
ronnyd
Quote from: Emd on 10 December 2013, 15:07:22
Yes EMD, i must agree with that, my 95 cd seemed a bit more solidly put together. ???
chrisgixer
Quote from: ronnyd on 10 December 2013, 15:34:36
Oh really? Is this the same pfl with the creaking door pockets? Yes that's much better built isn't it. ::)
Quote from: chrisgixer on 10 December 2013, 17:41:20
No never  ;D
chrisgixer
Quote from: Emd on 10 December 2013, 19:06:26
No never  ;D
Oh I think you'll find it is. ;D
No creaky door pockets here, but an intermittent tinny rattle from the passenger head restraint if no passenger. Grrrr.
;D
Quote from: TheBoy on 11 December 2013, 19:28:52
;D
That'll likely be the spring for the active headrest mechanism buzzing away. Pop the back off an place some sticky backed fluffy velcro where it's rubbing :y
Quote from: ex taxi al on 11 December 2013, 19:31:19
;D
PFL, no such luxuries at active head restraints ;D
I reckon wheel balancing may help ::)
MR MISTER
I've had numerous cars where the passenger seat belt buckle knocks against the side of the b pillar or the seat. Astra did it, zafira did it, this one does it. On the meriva I had, someone had stuck a piece of velcro by the side of it.
chrisgixer
Quote from: STEMO on 11 December 2013, 21:05:23
...and the Daewoo? ;D
