Wheel alignment settings: Haynes' vs WIM
Started by Webby the Bear, 11 December 2013, 21:36:24
Quote from: Webby the Bear on 13 December 2013, 13:54:51
ps never thought steve I coulda popped in to see ya!  :'( :'( :'(
You could have mate , and seen my new spanker car  :-X :-*
Webby the Bear
Quote from: Emd on 13 December 2013, 13:59:56
to be fair id have had a grotty 17 year old in toe though as I gave one of the morons a lift  ::)
hows she running mate?
RIP Paul Lovejoy
Golden bullet is running sweet mate  ;) Wearing my rear tyres out quite rapidly  ;D
Webby the Bear
Quote from: Emd on 13 December 2013, 14:04:54
:o :o :o ;D ;D ;D
one of the lads who put his car on the alignment machine (lowered fiesta) found his fronts were out by 2 degrees  :o :o :o :o no wonder he said it ran like a bag of shite! I adjust the tie rod for him to bring it in to spec... I just kept on turning...and turning... his tyres were shot!
RIP Paul Lovejoy
Quote from: Webby the Bear on 13 December 2013, 14:08:15
:o :o :o ;D ;D ;D
;D
Sounds more fundamental, if you adjust the tie rod then it should change the toe, shot tyres or not.
Webby the Bear
Quote from: Fuse18 on 13 December 2013, 16:21:42
oh it did come in to spec.... eventually lol it just took a lot of turns when usually an adjustment is done with 1/4 to 1/2 a turn lol
RIP Paul Lovejoy
Webby the Bear
ps, as mentioned the readings for toe on the O/S front is a single minute out when using WIM spec...... is a minute an amount that's going to have a bearing? im going to alter it anyway when ive done my bushes as we can request access to corby.....but I just want to know for whilst driving around before that...and also from learning point of view :)
RIP Paul Lovejoy
The thrust angle (set by rear toe) absolutely must be 0.00 on an Omega, to prevent pulls. 0.01 doesn't appear to be good enough - although maybe more pronounced with wider, lower profile tyres.
Webby the Bear
Quote from: TheBoy on 14 December 2013, 09:56:27
Ok thanks. How do you adjust the rear toe?
RIP Paul Lovejoy
Quote from: Webby the Bear on 14 December 2013, 11:56:50
By adjusting the rear track rods, which will be seized.
On the Omega, adjusting the rear track rods also affects rear camber, so there will always be an element of compromise. I'd compromise rear camber more than rear toe.
Webby the Bear
Quote from: TheBoy on 14 December 2013, 12:02:37
Oh goody  ::)
So its a case of adjusting the rear track rods (if possible due to the sezing) to bring the thrust angle in spec whilst maintaining rear camber in spec. this sounds straight forwad to me..... but I assume its not as everything omega is a PITA to do...or so it seems  ::)
RIP Paul Lovejoy
Webby the Bear
RIP Paul Lovejoy
Yup :y
They are available new as complete assemblies from Allgerman amongst others...
Probably also from the firm I linked for the wishbones etc :y
Webby the Bear
Quote from: ex taxi al on 14 December 2013, 13:14:56
Yup :y
nice one mate  :y :y :y
RIP Paul Lovejoy
