Wheel alignment settings: Haynes' vs WIM
Started by Webby the Bear, 11 December 2013, 21:36:24
Webby the Bear
Evening my Omega loving chums :) cold tonight :(
Oooook, as I've mentioned previously I am currently doing steering and suspension at the minute at school and we got told today that we've got to go to Corby Tresham to use their alignment machine.... it's a state of the art one (apparently) and as we don't have any money spent on the Wellingborough campus have one we are going over for a tutorial and a play  :y :y :y
The other great thing is they actually want us to put our own cars on it....free wheel alignment check off a dogs' bollerks machine :):):)
Now my car was last aligned by WIM and I know that the reason we take our cars over there is cos their research shows a different and better set up as opposed to the one the manufacturers recommend. SO. Below are the settings from the Haynes book of lies..... does anybody know what settings WIM use? :)
Front wheel alignment
Camber:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -1º40' ± 45'
Maximum deviation, left to right wheel . . . . . . . . . . . . . . . . . . . . . . . . 1º
Castor:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5º40' ± 1º
Toe-in:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0º10' ± 10'
Variation with inner wheel turned in at 20‡ . . . . . . . . . . . . . . . . . . . . . 1º40' ± 45'
Rear wheel alignment
Camber:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -1º50' ± 40'
Maximum deviation, left to right wheel . . . . . . . . . . . . . . . . . . . . . . . . 45'
Toe-in:
Saloon . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -0º20' ± 10'
Maximum deviation, left to right wheel . . . . . . . . . . . . . . . . . . . . . . . . 25'
*Note: Measurements taken and adjustments made with all tyres inflated to their fully laden pressures and the vehicle laden, i.e. a 70kg load in each front seat and a full tank of fuel.
RIP Paul Lovejoy
Webby the Bear
Ps, I'm trying to find out the make and model of machine if anyone's interested :)
RIP Paul Lovejoy
ffcgary1
Thos figs are strait out of the factory book, and are good when the car is new on new springs, dampers, and bushes, give it year, and lots of pot holes and kerbs and thos figs can be chucked away.
Jaguar XJ6
Webby the Bear
Quote from: ffcgary1 on 11 December 2013, 22:12:41
interesting. thanks gary....so do we know what WIM ''alter'' them to to take this in to consideration?
RIP Paul Lovejoy
If memory serves camber is a max of -1º 10' ...
EDIT :
just found my last printout.. Target values are ...
Rear camber  -2º 05' +/- 0º 40' Cross 0º 00' +/-0º 04
Rear toe   0º 00' +/- 0º 45' Total 0º 20'  +/- 0º 10'
Front camber -1º 10'  +/- 0º 45' Cross 0º 00' +/- 1º 00'
Front caster  5º 40' +/- 1º 00 cross 0º 00' +/- 1º 00''
Track Diff angle -2º 00'  +/- 0º 45'
Front Toe 0º 05' +/- 0º 05' total 0º 10' +/- 0º 10'
HTH  :)
Webby the Bear
Quote from: Entwood on 11 December 2013, 22:38:17
EDIT :
Front caster  5º 40' +/- 1º 00'
HTH  :)
LEGEND! Thanks Entwood. i'll print this out so I don't forget and see what we're at on the machine.
After asking my school buddies on Facebook it appears it's a Snap-on 3d 4 wheel aligner :)
RIP Paul Lovejoy
Welcome .. edited the above to include the total/cross values as well
Webby the Bear
RIP Paul Lovejoy
Webby the Bear
looking at the figures theres a noteable difference in camber at the front.
RIP Paul Lovejoy
Quote from: Webby the Bear on 11 December 2013, 22:53:27
I "believe" from talking to him, that the main changes are to both front and rear camber to take account of the age of the suspension, which, being older and softer sits the car lower.
YZ250
Can you take my car instead Webby as I've just replaced my wishbones and front struts so mine is probably shot to s*** now, despite my best efforts of taking measurements and marking the steering knuckle.  ;)
Only kidding. Looks like a trip to WIM is on the cards. Shame mine had to be upset really as its always driven true and tyre wear was even across the band.  Wonder what my settings will be as my suspensions all new.  :-\
Hope you have a good, informative day out.  :y
Webby the Bear
cheers boys.
ill take photos and post up full details :):):)
RIP Paul Lovejoy
wheels-inmotion
Point to note our figures are without any ballast added since most places in the UK don't have ballast. In addition the castor position is adjustable by moving the subframe.
Gaffers
Fancy cutting your teeth on a 97 XJR Webby? ;D
About to finish replacing shocks springs and bushes all round.  What a job that was!!
Webby the Bear
Quote from: wheels-inmotion on 12 December 2013, 11:10:19
Thanks for confirming that... so no additional weight in the front or the boot? :)
RIP Paul Lovejoy
