Zafira problem
Started by Rods2, 12 December 2013, 21:43:51
Rods2
My daughter has a 2007 1.8 petrol which has done 56k.
There is a whining sound when the car in moving, that is getting louder. Is it possibly a gearbox problem, cv joint or the beginning of a failing wheel bearing?
Quote from: Rods2 on 12 December 2013, 21:43:51
Likely a wheel bearing... the 1.8 doesn't produce enough torque to break anything :y
Get the car nice and warm, jack the wheels in turn and spin them. Listen/feel for any roughness or tightspots :y
henryd
Quote from: ex taxi al on 12 December 2013, 21:55:28
Also take the car up to about 50mph and knock it into neutral and see if the noise is still there,if its gone its probably drivetrain related,if its still there try gently weaving side to side and see if loading the bearings makes it worse :y
Edit don't do the neutral bit if its auto :y
other rides
MR MISTER
I can vouch for that.
No real issues with those gearboxes and the wheel bearings are pretty reliable, its also worth swapping tyres front\rear to rule them out
tidla
Changed a rear wheel bearing on one of these the other week. 09 plate but 100k.
Rods2
Quote from: tidla on 13 December 2013, 18:47:42
How difficult was the job?
Caliper/disc off, then four bolts :y
Worth checking caliper function too, as binding can cook the hub causing premature failure... suffered that at 25k on my first Vectra C. Nsr would be a good place to start :y
tidla
Quote from: ex taxi al on 13 December 2013, 21:01:12
wot he said^
