WTD 2.5 gearbox ECU and loom
Started by omegod, 13 December 2013, 15:35:19
omegod
Helping someone out who needs a gearbox ecu along with the wiring from ecu to the blue plug in the engine bay, 2.5 auto going into a Scimitar!
I may well have an ECU, but don't have the loom. Do you have a part number for the ECU ?
2woody
I'm sure I've got all the bits to make the loom.
pm coming
biggriffin
Ar 35 would be better its stronger than the 25.
Hoof'land storeman.
omegod
Cheers for the ideas , Rod if you read this can you pm 2woody as I think he can sort you out with something  :y
Post 1998, until about 2001, all the ECUs are the same, GS8.20, just run a different config. Post 2001, they are slightly different hardware to earlier ones (GS8.21(1)), to be compatible with the new EOBD style ECUs, again, need configuring to match engine.
Pre 1998, the ECU is not flashable, thus must be the correct one.
