Author Topic: rebuild  (Read 2338 times)
greenman
  • greenock
rebuild
« on: 14 December 2013, 12:45:35 »
Facelift 2.2
   Cambelt tensioner failed.
   Head rebuilt,new valves,stem seals etc.
   Cambelt kit.
   Starts fine. Put in drive and all the gear lights come on
   D 1.2.3. Goes into limp mode with spanner light on.
   Showing codes P1700(0)
                         P0170(2)
                                           Any ideas welcome ???
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: rebuild
« Reply #1 on: 14 December 2013, 13:18:00 »
Just found this for one code:
P1700 - CAN SVS REQUIREMENT
P0170 - Fuel trim fault
« Last Edit: 14 December 2013, 13:20:33 by blackviper90210 »
AKA - Mr Bracket
greenman
  • greenock
Re: rebuild
« Reply #2 on: 14 December 2013, 16:34:09 »
Don,t see how thiis would put it into limp mode.
Could there be a gear selector fault?
  • Auckland
    • Mazda MPV
Re: rebuild
« Reply #3 on: 14 December 2013, 16:48:22 »
Did you touch the gearbox? or was the head work done with the engine in the car?
Certainly worth checking that the selector switch is behaving itself but I think you need to start by checking the things that were disturbed when the head came off.
- are all the connectors securely connected to the correct sensors?
- are all the earth wires solidly fixed to their correct earthing points?
4 pot cam sensors are famous for bringing up random can-bus errors which give misleading diagnosis. It can also prevent the engine ECU from giving a sensible engine speed signal to the gearbox ECU. The gearbox ECU then gets upset and lights up all the selector lights.
My money is in the cam sensor but start by checking the sensor plugs and wiring........
greenman
  • greenock
Re: rebuild
« Reply #4 on: 14 December 2013, 16:52:26 »
Work done with engine in car so
gear box untouched.
Car now running rough at idle
Re: rebuild
« Reply #5 on: 14 December 2013, 17:22:17 »
Check the blue circular connector at rear of battery is secure
greenman
  • greenock
Re: rebuild
« Reply #6 on: 16 December 2013, 14:36:13 »
seems to have been blue connector
cleaned and refitted all connectors disturbed when
doing cylinder head.
seems fine now
thanks for replies
