Author Topic: Topping up autobox...  (Read 3693 times)
Re: Topping up autobox...
« Reply #15 on: 20 December 2013, 14:24:29 »
Hahahahahahahaha.......................hahahahahahaahahahaha
Just topped up my autobox. The physical act of filling went well. The cuprinol sprayer pipe fits like a dream..... I could leave it in while pumping away. Got a nicely full autobox now.
However, what didn't go so well was when I pulled the hose out from the box when it started running out  ;D ;D ;D ;D ;D ;D
I negated to consider the residual pressure that would be in the sprayer thus when I pulled the hose out I got covered. and I mean COVERED! hahahaha I couldn't get the lid off to release the pressure as id done it up too tight
So got the road outside the house covered as well hahaha
Note to self: take car to far away place when next topping up  ;D
Yes they do work well  :)
Always worth remembering to let pressure out when done though  ;D
« Reply #16 on: 20 December 2013, 18:16:01 »
Which is where a suitably sized plastic tube 'screwed' into the fill/level hole wins  ;D. You're only pouring a small amount of oil in at a time, and when the oil starts to show a level in the bottom of the tube, the gearbox is full. I then jacked the side of the car a little so I could remove the filler tube & re-fit the plug.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #17 on: 20 December 2013, 22:35:34 »
if I had half a brain Andy I'd have at the very least put a catch pan underneath. I didn't bother as I thought ''only a bit will trickle out'' so I just put my usual cardboard under  ;D ;D ;D stupidly wasn't expecting 2 million bar of pressurised ATF straight in my face, all down my coat and all over the floor  ;D ;D ;D
RIP Paul Lovejoy
« Reply #18 on: 20 December 2013, 22:52:52 »
.... stupidly wasn't expecting 2 million bar of pressurised ATF straight in my face, all down my coat and all over the floor  ;D ;D ;D
I assume you were using the sprayer without the trigger  :-\
Webby the Bear
  • Northampton
« Reply #19 on: 20 December 2013, 23:05:10 »
Correct...just the tubing  ;)
RIP Paul Lovejoy
« Reply #20 on: 20 December 2013, 23:11:43 »
Perhaps a pair of Mole Grips or brake hose clamp at hand might be a good idea if you do it again  ;)
« Reply #21 on: 20 December 2013, 23:12:00 »
Not the same bit of cardboard  ;D ;D
« Last Edit: 20 December 2013, 23:16:28 by Emd »
