Author Topic: Windscreen washer's  (Read 1500 times)
Windscreen washer's
« on: 15 December 2013, 16:24:48 »
Seems to be a delay in the water coming out of the jets  ??? Blades sweep at least once before any water hits the screen , is that normal  ???
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: Windscreen washer's
« Reply #1 on: 15 December 2013, 16:31:40 »
If it isn't normal there's something wrong with mine as well  :-\
Spray from lights hits my screen first  ::)
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #2 on: 15 December 2013, 16:58:03 »
If not used for a while it will come from lights first because of length from washer bottle.  :y
« Reply #3 on: 15 December 2013, 17:51:30 »
Is there no non return valve in the plumbing then :-\
« Reply #4 on: 15 December 2013, 18:50:41 »
the only connection between the screen washers & headlight washers in the bottle they pumpfrom ..... two separate pumps.  ;)
« Reply #5 on: 15 December 2013, 18:51:17 »
What's the filter like? Is it full of gunge?  :-\
« Reply #6 on: 15 December 2013, 18:56:16 »
« Reply #7 on: 15 December 2013, 19:11:52 »
I will check the filter , thank you oh wise ones
