engine change
Started by pauls, 15 December 2013, 21:31:16
pauls
Just thinking out loud really. How easy would it be to swap my engine out with a 3.2.
list of things needed.
Engine
gear box
3.2 ecu ?
diff ?
millwall
why not just buy a 3.2 less hasstle
Quote from: pauls on 15 December 2013, 21:31:16
Engine
gear box
3.2 ecu ?
diff ?
Assuming yours is auto, engine/box and diff and loom. Just unplug 3.2 loom at ECU and plug into your ECU. 3.2 will run with the 2.6 ECU
chrisgixer
Quote from: millwall on 15 December 2013, 21:37:51
I see where he's coming from. Pauls has done a lot of work on his car that's not engine related. Arguably, its easier to swap the 2.6 for a 3.2. Than do all that other work again. ...it's the devil you know.
Personally I'd keep the 4.22 dif of the 2.6 though. :)
pauls
So list is..
engine
gearbox
ecu+loom
Plus some nice oof person to fit for me.
O well something to think about.
Quote from: pauls on 15 December 2013, 23:11:29
So list is..
engine
gearbox
ecu+loom
As said ^^^^^^^^^^3.2 will run quite happy with 2.6 ECU
Quote from: RobG on 15 December 2013, 23:12:37
So list is..
engine
gearbox
ecu+loom
Don't need the loom either :y electrically they are identical :y
Quote from: ex taxi al on 15 December 2013, 23:15:51
So list is..
engine
gearbox
ecu+loom
For ease of installation Al
Either or... :y
Leave the loom in the car or swap it from old engine to new or just swap the lot over :y
Personally I would keep the 2.6 loom if the car currently has no gremlins...
pauls
Quote from: chrisgixer on 15 December 2013, 22:57:26
As Chris said above I have done a lot of work to the car but just want a bit more power. I have looked at other 3.2 s  for sale but that would mean I would have to start all over again with a car I dont know. If I just change the engine,gearbox at least I will only need to keep an eye on them :y
biggriffin
Ffs all your doing is an engine and box change. Out with the old in with the new.
unbolt propshaft from gearbox,unplug lectrics, undo and remove downpipes.
remove bonnet,unplug lectrics,unbolt mounts,remove radiator pack, disconnect battery,
then remove, installation is the reverse of removal...
Hoof'land storeman.
chrisgixer
Quote from: biggriffin on 16 December 2013, 09:50:01
No need to remove bonet even, provided lift strap is short enough. ;)
chrisgixer
It's also a good chance to re seal the sumps and make it a bit more oil tight in the usual places. Inspect the bottom ends and make sure the sump pick up is clear, all while the engine is out.
biggriffin
If you want to do a proper job, then before dropping the new lumps in, fit new crank sensor, new hbv and a thermostat and cambelt,and as you said take the sump off, lot easier to do all these jobs on a stand than in the car.
and the reason i said remove the bonnet,was when removing engine and box as a unit it gives more space when lifting,to get the clearence on the slam panel,.
Hoof'land storeman.
8 bolts and a four post lift and you can drop the engine straight onto the floor ::)
