Filling autob using Cuprinol sprayer
Started by Webby the Bear, 16 December 2013, 17:44:45
Quote from: TheBoy on 16 December 2013, 18:24:45
'dangle berries', I forgot to put it on my loss list. Grrrrr.
I think yours maybe at mine?  :-\
omegod
Funnel taped to the wing mirror and some tubing does for me!
Quote from: Andy B on 16 December 2013, 21:47:22
Quote from: Webby the Bear on 16 December 2013, 21:17:40
Quote from: Andy B on 16 December 2013, 19:47:40
plastic tubing is a couple of quid per 3'  3 3/8"  ;)
Already got that Andy....had to buy a couple of metres when experimenting with the oil extractor.  :y
Really wanted it on ramps as, although admitting weakness, I hate getting under the Omega. Fekking thing scares the shit out of me. However luckily the autobox sump isn't as far inwards from the side as I thought.... I can JUST about get to the level plug with my hand and only half my face under the car  ::)
Mine was on ramps and axle stands  :y
Despite the axle stands and ramps, I'd still get the willies getting underneath that!!  :-\  :-[
Mines got a nice scuff on the front bumper just like yours!!!  :)
Quote from: Sir Tigger on 16 December 2013, 22:17:04....
It was steady as a rock  :y :y :y
Quote from: Sir Tigger on 16 December 2013, 22:17:04Mines got a nice scuff on the front bumper just like yours!!!  :)
The photo is a few years old and has since been sorted. I bought the car with the scuff & in my naivety thought that the bumper would be made up of several bits like a Senator's bumper was ....... they're not though.  ???
SIR Philbutt
#19
I used a 1 ltr box fluid bottle with a pipe pushed in almost to the bottom. Think it was a wine siphon pipe that was a tight fit through the top
Used it to suck the old fluid out and then filled with new and squeezed, fluid goes uphill. Still got it in my garage for next time. Cost £0.
I did have the car up on a lifter so a bit easier than lying under the car and doing it
I seem to recall someone posted a picture of one you can buy, that's where i got the idea from.
biggriffin
Quote from: Webby the Bear on 16 December 2013, 21:18:10
Quote from: biggriffin on 16 December 2013, 20:57:38
I use a fence sprayer, holds 8ltr put the pipe in the gearbox,pump it up and just watch the fluid disappear :y
nice one BG.... is it the cupriol one you use?
i think it is a cuprinol one, i just cut the sprayer end of. Then you just give it half a dozen pumps,to build the pressure up and whoosh out it comes.
Hoof'land storeman.
Webby the Bear
Quote from: biggriffin on 17 December 2013, 10:28:34
Exactly what I was thinking! cheers mate  :y
to sir tigger and andyb....
I'd be a lot more confident with that set up you've got there andy, especially as those stands look like the big 3 ton each ones.... but I, like ST, get pretty nervous about going under the car full stop. I think its cos of the weight. ive got no issie going under fiestas and astras at school all day long but the omega...  :'( maybe its just in my head.
RIP Paul Lovejoy
Cant seem to get mine up on the ramps , the ramp pushes away from the wheel if you try and drive forward onto them  :( Would help if the hand brake worked  ;D
Quote from: Emd on 17 December 2013, 12:39:06.....
That's what those galvanised extensions are for  ;) They hook onto a lower rung of the rampto give a shallower angle so the wheel meets the ramp before the lower edge of the spoiler does.  ;)
Quote from: Andy B on 17 December 2013, 14:08:36
Ah yes i remember you saying a while back now about those  ;)
