Filling autob using Cuprinol sprayer
Started by Webby the Bear, 16 December 2013, 17:44:45
Webby the Bear
Hi guys.
Ok, struggled to get fluid in to the auto box sump using just the extendable nozzle on the bottle.
I saw in the guide that the chap used this to fill it up...
http://www.diy.com/nav/fix/power-tools/painting-decorating-power-tools/Cuprinol-Fence-Sprayer-11517562
is it just a case of removing the spray gun and pumping it up will force the fluid out?
Sadly I cant use the ramps at school to do this :( so ill be buying this to do the work :)
RIP Paul Lovejoy
Quote from: Webby the Bear on 16 December 2013, 17:44:45....
Yes.
I filled mine though by screwing a suitable sized plastic tube into the fill/level hole, route the other end into the engine bay & stick a funnel into it. Fill a bit at a time a make sure it all goes into the gearbox ....... it makes a mess on the drive the tube comes out of the g/box ........ apparently!  ::) ::) ::)
Webby the Bear
Quote from: Andy B on 16 December 2013, 17:50:03
Yes.
;D ;D ;D
I planned on jacking it up and holding the pipe in whilst some other mug a buddy pumps away
RIP Paul Lovejoy
I used a Wilko £6 garden sprayer. Easier than pissing around with 1l bottles, around the hot exhaust.  I'd tend you mine, only it was plastic, and melts easy ;D
Quote from: Webby the Bear on 16 December 2013, 17:52:17.....
If the plastic pipe is the right size, it'll hold itself in and you can fill the box using gravity or the garden sprayer.  ;)
Webby the Bear
Quote from: TheBoy on 16 December 2013, 17:53:20
;D Cheers TB.
For £6 ill go there instead of the £23 b&q want!!!  :y
RIP Paul Lovejoy
Just looked online, £17 now :o
See what price it is in store. I know I paid £6 for the last one...
Webby the Bear
Quote from: TheBoy on 16 December 2013, 18:01:29
Will do mate, cheers  :y
RIP Paul Lovejoy
'dangle berries', I forgot to put it on my loss list. Grrrrr.
plastic tubing is a couple of quid per 3'  3 3/8"  ;)
Quote from: Andy B on 16 December 2013, 19:47:40
I used a bit of garden hose and a funnel in the engine bay. But garden sprayer was easier.
biggriffin
I use a fence sprayer, holds 8ltr put the pipe in the gearbox,pump it up and just watch the fluid disappear :y
Hoof'land storeman.
Webby the Bear
Already got that Andy....had to buy a couple of metres when experimenting with the oil extractor.  :y
Really wanted it on ramps as, although admitting weakness, I hate getting under the Omega. Fekking thing scares the shit out of me. However luckily the autobox sump isn't as far inwards from the side as I thought.... I can JUST about get to the level plug with my hand and only half my face under the car  ::)
RIP Paul Lovejoy
Webby the Bear
Quote from: biggriffin on 16 December 2013, 20:57:38
nice one BG.... is it the cupriol one you use?
RIP Paul Lovejoy
Quote from: Webby the Bear on 16 December 2013, 21:17:40
Mine was on ramps and axle stands  :y
