Author Topic: quick question for the plumbers and builders  (Read 1056 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 18 December 2013, 10:08:56 »
I am putting up some shelves in the kitchen in to a false wall (plasterboard wall protruding in to the kitchen) next 5o my combi boiler which is mounted on the same false wall.
Drilling through the plasterboard I have hit something hard and I want make sure I am not going to damage anything by drilling through it.  It seems like it could a fibreglass support mounted behind the plasterboard for the boiler but I am a little concerned about what it is. I do t want to drill a pipe.  My stud detector says there isn't any electric wiring there but it cannot detect pipes.  The metal detector goes off but then it is within 6 inches of the boiler.
I have drilled exploration holes leading away from the boiler and this thing stops about 11 I ches away from the boiler.
so the question is, what is it and can I drill it?
darrenfos
  • eastleigh
    • omega elite manual
Re: quick question for the plumbers and builders
« Reply #1 on: 18 December 2013, 19:21:00 »
if its a false wall as you say, you should have at max have the stud work timber depth which with the proper plugs should be enough without hitting anything the other side. also try putting a long screw though the hole and just tap it, you should here it ring if its a pipe. Do not carry on if your not sure though.
omega is like marmite you know the rest
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 18 December 2013, 19:38:46 »
A 3/8" hole and torch should allow you to see what it is, or if not, just cut a small square out to investigate, then polyfilla it back in. :y
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #3 on: 18 December 2013, 21:50:14 »
Just keep drilling and tell Mrs G that's where the ornamental fountain she has always wanted is going.  ::) ::) ::) ::)  :P ;D ;D ;D ;D
