Author Topic: Crankshaft Sensor  (Read 1665 times)
mike clark
  • hull eastyorkshire
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
Crankshaft Sensor
« on: 20 December 2013, 12:08:42 »
seen one on ebay can you use second hand ones and thanks to all the replies
it was my steering pump car is 10 times better thanks steve
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Crankshaft Sensor
« Reply #1 on: 20 December 2013, 12:14:22 »
you can. but how'd you know if its failed or not?
I bought a pas pump off the bay. it was as fekked as the one I was replacing
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #2 on: 20 December 2013, 12:14:49 »
to add, I wont make that mistake again
RIP Paul Lovejoy
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 20 December 2013, 12:24:01 »
Consider that you can't test it's condition, that it's essential for the engine to to work, and that a new is about £60. That all makes a secondhand crank sensor a very poor buy.
mike clark
  • 2.5 v6 cdi
    • omega 2.5v6 cdi
« Reply #4 on: 20 December 2013, 12:39:14 »
a new 1 it is then thanks lads
« Reply #5 on: 20 December 2013, 16:10:02 »
Fit genuine Vx mate, not pattern ;)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #6 on: 23 December 2013, 17:20:12 »
No worries Mick  ;D
You have got my number unless you have lost it again you cock  ::) ;D ;D ;D ;D
Ref Crank sensor ...............
Definitely the sensor on its way out mate.
The only code present when I read them was 19 (no rpm signal)  ;)
As I said, if it goes then your engine stops, end of so get it sorted asap  ;)
