Author Topic: knocking / clunking sound  (Read 3784 times)
darrenfos
  • eastleigh
    • omega elite manual
« on: 20 December 2013, 18:56:04 »
hi all regarding the omega (2001 elite manual estate) there is a knocking or clunking noise from underneath at the front somewhere when i had a look there's nothing loose or out of place, seems to drive ok no wobble or pulling it seems to be quieter as speed increases at first i thought it was engine tray or something that's what it sounds like, its a bit strange. Had its tracking done when all 4 tyres were replaced about a month ago. the noise was there before that though. :)
omega is like marmite you know the rest
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: knocking / clunking sound
« Reply #1 on: 20 December 2013, 19:20:42 »
I would suspect your droplinks are knakard :)
Hoof'land storeman.
darrenfos
  • eastleigh
« Reply #2 on: 20 December 2013, 19:29:59 »
i thought that may be the case any way to tell or test
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #3 on: 20 December 2013, 19:37:07 »
You can get the front wheels off the ground and then put a bar under the anti-roll bar near the drop link and lever it up. You will clearly see if there is play in the drop link ball joints. I use my trolley jack handle for this.
darrenfos
  • eastleigh
« Reply #4 on: 20 December 2013, 20:30:20 »
anyone know how much both front drop links are from vauxhall, cheers.
« Reply #5 on: 20 December 2013, 20:40:56 »
They recently jumped up, used to be a very reasonable £15 or so each, think they are quite a bit more now  :(
Some of us have experimented with pattern, I got MeyleHD ones. As some people here recommended them, have to say they are well made, very solid compared to GM's.
Been on around a year or so now, time will tell but no complaints so far  :y
darrenfos
  • eastleigh
« Reply #6 on: 20 December 2013, 20:43:21 »
cheers, will have a look around
« Reply #7 on: 20 December 2013, 20:46:26 »
These are the ones I bought:
http://www.allgermanparts.co.uk/ourshop/prod_2034029-Front-anti-roll-bar-link-Meyle-HD-version-4-year-warranty-616-060-5575HD.html
Like I say, impressively made (4 year warrenty), considering GM were a similar price but time will tell  :y
« Last Edit: 20 December 2013, 20:48:38 by tunnie »
darrenfos
  • eastleigh
« Reply #8 on: 20 December 2013, 20:49:16 »
was just looking at the very same thing will order them, cheers mate.  :) :)
« Reply #9 on: 20 December 2013, 20:50:09 »
Ask to speak to Jason, he knows OOF well. Worth a mention, often get a discount or faster delivery  :y
chrisgixer
« Reply #10 on: 20 December 2013, 21:07:18 »
If the car is on level ground you can just reach under and grab the roll bar nearest the drop link ball joint, and pull up and down. You'll feel the play in your hand.
The car MUST be level to check by hand though, because if the roll bar is loaded up, jacked in one side for example, then the roll bar will be twisted and all the play will be taken up by the torsion off the roll bar, and you'll never shift it.
Lemforder, Merle seem ok, or Gm give good results. I wouldn't go for anything cheaper personally, but each to their own, as they say.
If its not drop links, loom for knackered wishbone bushes allowing the wishbone to knock on the subframe. But it would handle shite if it was those.
« Reply #11 on: 20 December 2013, 21:10:22 »
Didn't Jimbob have warranty issues with those droplinks :-\
« Reply #12 on: 20 December 2013, 21:11:55 »
Don't know, missed that one if he did. Were the issues with allgerman or Meyle?  :-\
If they last a few more years I'd be happy  :y
« Reply #13 on: 20 December 2013, 21:15:02 »
Meyle iirc :-\
The ones I get for tuppence from Germany last about 30k...
darrenfos
  • eastleigh
« Reply #14 on: 20 December 2013, 21:16:18 »
just grabbed the drop link passenger side and it moved a bit when i pushed and pulled it drivers was pretty solid
Page created in 0.011 seconds with 14 queries.
