Author Topic: Get ready for a wet and windy one  (Read 2388 times)
MR MISTER
« on: 22 December 2013, 22:05:53 »
Was that...
A) Me listening to the weather forecast?
B) Me warning the wife about what's to come later?
Re: Get ready for a wet and windy one
« Reply #1 on: 22 December 2013, 22:12:18 »
Have you had you evening bowl of Branflakes with warm milk then ::)
MR MISTER
« Reply #2 on: 22 December 2013, 22:12:46 »
Horlicks.
« Reply #3 on: 22 December 2013, 22:31:57 »
Horlicks.
Same to you :o
Nickbat
« Reply #4 on: 22 December 2013, 22:37:06 »
Was that...
Incredibly strong jet stream. I saw a tip about this on a weather forum.
A Boeing 747 normally has a max cruising speed up to Mach 0.88 (583kts). I just noticed a 747-800 (Polar Air) flying east at 636kt (731mph)!!!  :o :o :o
http://www.flightradar24.com/PAC956
« Reply #5 on: 22 December 2013, 22:38:58 »
Never knew TB drove 747's  ;D  ::)  ::) ::)
Nickbat
« Reply #6 on: 22 December 2013, 22:48:38 »
Strongest jet stream this forecaster has seen:
http://www.bbc.co.uk/weather/features/25485532  :o
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #7 on: 22 December 2013, 22:49:10 »
It all those Christmas sprouts washed down with good strong stout, that will cause it.  ;) :P :o :o
Rods2
« Reply #8 on: 22 December 2013, 22:50:37 »
Not so good if you are flying in the opposite direction.  :o :o :o :o
Nickbat
« Reply #9 on: 22 December 2013, 22:59:44 »
Was that...
I suppose that raises an interesting engineering question. I presume that an aircraft can exceed its max speed if it pushed by a tail wind since the air resistance is so much lower that it does not stress the airframe. Thus, in theory at least, a 747 could break the sound barrier if it has a strong enough tail wind?  ???
« Reply #10 on: 22 December 2013, 23:01:22 »
Jet stream is "relatively" narrow, especially the strongest, core element ... so by going 100 miles north or south it makes a big difference to winds ...
NAT tracks - North Atlantic tracks - are computor generated  to optimise costs/time for all crossings.
jetstream predictions ..
http://www.netweather.tv/index.cgi?action=jetstream;sess=
Nickbat
« Reply #11 on: 22 December 2013, 23:03:32 »
Was that...
That flight is now showing 660kts (759mph!!) :o
« Reply #12 on: 22 December 2013, 23:04:22 »
If you think Monday/Tuesday is going to be rough...
Check out Friday early morning here...
http://magicseaweed.com/North-Atlantic-Surf-Chart/2/
As it comes round again :o
« Reply #13 on: 22 December 2013, 23:06:43 »
Was that...
nope .. as the speed of sound is also affected by the speed of air movement .. exceeding the speed of sound means exceeding the RELATIVE speed of sound in your locale .. or the "air speed" .. the mach ratio remains the same regardless of windspeed,   so mach .65 in still air is 430 knots ground speed .. in 100 knot headwind its 330 knots ground speed, in a 100 knot tailwind its 530 knots ground speed ... the "airspeed" or mach no remains constant ...at 430 knots / .65
« Reply #14 on: 22 December 2013, 23:08:38 »
Was that...
Speed over ground is very different to airspeed, if a 747 went super sonic it would probably have bits fall off.
Also they're the wrong shape for it... a Boeing 727 is/was the fastest subsonic commercial aircraft...
