Impact Wrench
Started by tunnie, 23 December 2013, 16:10:10
Feel like treating myself to a gadget, to make things easier for car stuff.
I've been impressed with my every day DIY Makita..
http://www.amazon.co.uk/Makita-BTW251Z-Li-ion-Impact-Wrench/dp/B000YNEN6U/ref=sr_1_4?s=diy&ie=UTF8&qid=1387814633&sr=1-4
Any recommendations?
Not sure what make Chris' one is, but it's compact enough to be useful :y some are too bulky for much more than wheel bolt removal  :-\
Yes do like this, but have a feeling that was twice the price of the above.
Think he got his from states?  :-\
biggriffin
If you are going to be using it on a regular basis,then a rechargeable type is ideal, but for occasional use then machine mart/sealey do a 240v corded one.
Hoof'land storeman.
Needs to be cordless charger type really  :)
biggriffin
Fair enough.  Just remember every so often,to run it totally flat,to preserve the battery. Might be an urban myth with the newer batterys..
Hoof'land storeman.
Check that one uses same batteries as you kit, else the cost will become pretty heavy.
230Nm isn't anywhere near enough to undo wheel bolts, but will pop them out once you've cracked them with a breaker.
I have a Makita cordless drill/driver that I bought about 6 months ago when my Focus own brand drill died after about 6 years. I paid about £90 for the Makita and about £20 for the Focus drill.  I was always really pleased with the cheap drill, but have been less pleased with the Makita.  :(
Maybe if the Makita is still going strong in 20 years I'll be more impressed!!  :-\
chrisgixer
Check your battery set is in good nic and not due to be replaced by a newer model range, as your batteries will be extremely hard to get hold of in a very short space of time once the new model is out.
But I'm guessing from the slide on body shape that its the newer set they all swapped over to from the slap in style ones of old. Batteries and charger are absolutely key to the set obviously, as you've probably heard the master say on here on other threads.
Lithium ion need constant use to keep the batteries tip top, each time I go out to the garage I stick one in charge, keep them rotated and fully charged to keep the electrons(?) moving or they'll drop of the charge scale and the charger won't switch on complaining the batteries are caput.
If its only occasional use go for ni cad as they hold the charge better over long periods I believe, but check that info first I have no experience with them.
You'll also find the body only is cheaper in the states. Less than half price ime. Costco wanted little under £190 for the body only. I paid £90 incl duty from the states. And it was better spec, with a built in torch attachment none of the uk ones had. (Obviously the charger needs to be uk spec)
My one is a tiddler. It won't do wheel nuts at 110nm. It probably does 90 to 100nm absolute max fully charged, and about 70nm average over a complete discharged battery. But it's VERY handy in small species. Loosen off first. Short reach, narrow body., fits on wishbone bolts, under sills for donut bushes where the big powerful ones are too long and bloody heavy for under car work where you have to hold it above your head.
In all honesty I was going to go for a snap on one for wheel nuts. But with use of  my tiddler after a while I don't think its worth the cost. You have to get the torque wrench out to do the bolts up anyway, so I use that to brake the nuts loose, then wiz them out with the orgazma gizmo. Wiz back in on refitting, torque up, jobbed. It saves so much agro, its light and useful more jobs than a big one would be.
The only thing I don't like about mine is the trigger. Its a switch. It's either flat out or off. It really needs the control of a progressive trigger tbh, the risk of cross threading would be massively reduced. Not that I've had a problem with that so far.
Brilliant little things they are. ...try not to get it wet though. ::)
How about this?
http://www.machinemart.co.uk/shop/product/details/clarke-cir220-24v-cordless-impact-wrench-2
Tested here, came out ok. Comes with 2 batteries (Ni-Cad) so suits my use, case and some sockets.
Not bad for price?
http://www.autoexpress.co.uk/accessories-tyres/65787/clarke-cir220
I've had an 18v Duralast impact wrench for a while, which is pretty small, but rated to 210Nm. Like Chris, I find it barely has the guts to loosen correctly tightened wheelnuts. But, I use it in exactly the same way; winding in long/large bolts, or on pullers and spring compressors which it does really well. I find that the ordinary air impact wrenches are similar unless used with a really big compressor.
They're really handy, but at about £200 for something worthwhile are still a luxury. As always with cordless tools, the battery quality is critical.
Quote from: tunnie on 24 December 2013, 16:17:31
How about this?
Not bad for price?
For the body size and price, the similar, slightly more expensive 450Nm one (which is what I had), seems to make more sense.
Quote from: TheBoy on 24 December 2013, 21:52:44
How about this?
Not bad for price?
Is a Vat free day due?
lee4206
Quote from: tunnie on 24 December 2013, 22:13:39
How about this?
Not bad for price?
Mine came through yesterday for Jan 5th and 12th.
Quote from: lee4206 on 24 December 2013, 22:51:03
How about this?
Not bad for price?
I don't always get them via email, here is hoping  :)
