Author Topic: Drivers door unlocked but wouldn't open  (Read 2201 times)
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« on: 24 December 2013, 15:41:19 »
Just spent and entertaining couple of hours hacking a hole in the drivers door card to get at the lock mechanism, the central locking worked fine but you couldn't open the door with either handles.
A search through the forum turned up this thread
 http://www.omegaowners.com/forum/index.php?topic=83372.msg1090455#msg1090455
Mine was in one piece and not as worn..
After breaking off the plastic cover over the lock I found a lever that operated on the four pointed cog just wasn't engaging properly, by the use of a screwdriver got the lever to engage and the lock came open...
Its a bit of a struggle getting in the passenger side and clambering over to the other side...
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
Re: Drivers door unlocked but wouldn't open
« Reply #1 on: 24 December 2013, 16:41:10 »
At least you got it open, replacement card shouldn't be to bad money wise
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
« Reply #2 on: 25 December 2013, 10:35:47 »
Door cards no longer available from GM, so you'd have to get one from a breaker.
