Author Topic: EML on after dis pack change  (Read 1783 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 29 December 2013, 08:49:59 »
X84GNB 2.5 petrol manual estate
Have changed dis pack. On start up EML went out, but came on after 1 minute. Codes 1 2 1 2 1 2 1 3 2 1 3 2 1 3 2 1 7 1 7 1 7 1 2 1 2 1 2 1 3 2 1 3 2 1 1 3 2 1 7 1 7 1 7 Plug into plenum dual ram switch seems secure this time. What else could it be?
Re: EML on after dis pack change
« Reply #1 on: 29 December 2013, 10:51:52 »
Check EGR connection and connection to N/S knock sensor
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 29 December 2013, 12:15:04 »
Thanks Rob. EGR connection is OK, but cannot find n/s knock sensor. Where is it?
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #3 on: 29 December 2013, 12:42:09 »
Next. Seek a brown connector, mate!  ;) and a code reading is also recommended as give some tip to sort the problem out!  :)
« Last Edit: 29 December 2013, 12:44:20 by Johnny English »
C20NE - X25XE
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 29 December 2013, 12:50:28 »
Found cable to knock sensor, below wiring harness on n/s. It was disconnected. I reconnected it. EML light is still on. Codes still 1 2 1 2 1 3 2 1 3 2 1 3 2 1 7 1 7 1 7 1 2 1 2 engine running.
« Reply #5 on: 29 December 2013, 13:54:44 »
12
132
17
12
The 17 will possibly be left over from the knock sensor being disconnected, so check 132 in the code list (maint guides)
terry paget
    • 3 Astras 2 Vectra
« Reply #6 on: 29 December 2013, 14:40:25 »
Thanks.17 is knock sensor, I have corrected that. 132 is Exhaust Gas Recirculation Valve Incorrect Feedback Signal. I blanked off the EGR valve in the summer as it was leaking. No EML then. However, the top of the valve - the electric bit -  is very loose. Could this be the problem?
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 31 December 2013, 19:48:48 »
Last night I found an old EGR valve top in my pile of bits, so I fitted it. This one was not loose in any way. But the light stayed on.
This morning I took the car down town. The light was on when I left home, but when i reached my print shop half a mile away the light was off. Since then I have driven 30 miles, and the light has behaved normally. So all is well. Thanks to all for help.
