Author Topic: Complete brake failure!!  (Read 10524 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 29 December 2013, 08:50:13 »
During the drive home last night I noticed something was amiss with the brake pedal and brakes, The brakes were still working fine but I noticed that the pedal was slowly sinking away under my foot when I was applying pressure although the car was still slowing at a good rate. Then during the drive to work this morning first roundabout I approach and the pedal just drops away under my foot completely and the next thing I know I'm trying to push my foot through the bulkhead!!
Can the brake servo have possibly given up the ghost?! As much help as possible would be great so I can pinpoint a few things to investigate after my shift today as I need the car to get to from work!
Re: Complete brake failure!!
« Reply #1 on: 29 December 2013, 08:55:51 »
What's the fluid level like?
P6UL K
  • Dartford, Kent
« Reply #2 on: 29 December 2013, 08:59:34 »
I'll have to do get back to you on that one James as I'm currently driving to Brighton for a delivery
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 29 December 2013, 09:17:49 »
Servo failure is very rare(it's a very simple device), and makes the pedal hard.
You're looking for a fluid leak, have a quick look at the calipers and the hoses that lead to them.
But the most likely cause is a faulty master-cylinder.
« Reply #4 on: 29 December 2013, 09:20:14 »
That'd be my guess too
P6UL K
  • Dartford, Kent
« Reply #5 on: 29 December 2013, 16:12:35 »
Completely empty!
« Reply #6 on: 29 December 2013, 16:24:17 »
Get hunting for the leak, then ;D
P6UL K
  • Dartford, Kent
« Reply #7 on: 29 December 2013, 16:40:35 »
I have!
All 4 calipers and their flexi hoses are dry as a bone with no sign of any fluids inside the rims or on the ground.  AFAIK there aren't any other rubber brake hoses are there?
« Reply #8 on: 29 December 2013, 17:02:12 »
Has some Muppet fitted non vented discs to the rear?
  • Auckland
    • Mazda MPV
« Reply #9 on: 29 December 2013, 17:18:30 »
It is possible for a seal or seals to fail in the master cylinder and allow fluid to get sucked into the servo. From there it  passes into the inlet manifold and disappears in a puff of smoke (so doesn't leave any puddles as evidence). Never heard of it happening to an Omega though  :-\
« Reply #10 on: 29 December 2013, 18:53:35 »
Is this the diesel one or the 3.2 :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 29 December 2013, 19:07:19 »
I have!
It doesn't have to be a flexy hose that's failed,steel pipes can and do corrode and burst
other rides
« Reply #12 on: 29 December 2013, 19:23:54 »
I have!
Don't ignore the clutch... although, it's designed to fail long before the brakes do, making it almost impossible to drive before the brakes fail :o
If the clutch works, you still have fluid in the system, the level in the brake reservoir is different to the level under the cap...
« Last Edit: 29 December 2013, 19:26:38 by ex taxi al »
P6UL K
  • Dartford, Kent
« Reply #13 on: 29 December 2013, 19:24:14 »
I'll have to let you know in the morning Mark
P6UL K
  • Dartford, Kent
« Reply #14 on: 29 December 2013, 19:25:23 »
The thorn in my side mate - the hearse.
