Author Topic: Thermostat.  (Read 2767 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Thermostat.
« on: 29 December 2013, 14:20:39 »
Has anyone changed the thermostat on a 2.6 V6 and is it as horrendous as I fear?
Ron.
Re: Thermostat.
« Reply #1 on: 29 December 2013, 14:26:21 »
See the guide in Maintenence Guides.
Its a bit of a fiddle, but DIYable
martin42
Re: Thermostat.
« Reply #2 on: 29 December 2013, 14:30:45 »
Allow for a new transfer tube,which does come with both o rings,approx £15+vat,thermostat it self can be changed,i got mine from unipart for £12 but from what ive heard last week is unipart has closed down and in liquidation,use proper thermostat gasket from vx,pattern 1s are not a good fit.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Thermostat.
« Reply #3 on: 29 December 2013, 17:31:22 »
the Wahler thermostat is I believe the same as the GM but with the GM name filed off. Much cheaper than GM. Quite a lot of stripping down to fit but well worth it if yours is sticking. Mine was staying open only a fraction but with the replacement heating up of the system is much quicker. It is said to improve MPG as well
Bigron
  • Witham, Essex
Re: Thermostat.
« Reply #4 on: 29 December 2013, 18:33:17 »
Thanks, Robson., and all other answerers. Where can I buy a Wahler thermostat? I looked up Unipart, as suggested, and found them to be expensive.
I certainly do need a new one as my car takes ages to show any increase on the temperature gauge - not good with the weather we are now moving into!
It will also adversely affect fuel consumption with the engine taking so long to reach its efficient operating temperature and I can't afford the extra petrol!
Ron.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Thermostat.
« Reply #5 on: 29 December 2013, 18:52:34 »
Try Vauxhall world parts. Good service and mainly oe parts (ive found) there in barking i think.
Hoof'land storeman.
sjr47
Re: Thermostat.
« Reply #6 on: 29 December 2013, 19:04:35 »
Fitted a Wahler stat on my 2.6 earlier this year and working all OK, one thing to note is the flange is thinner than original so shorter bolts or cutting down of originals req,d,yep fitting is a pita but you will get there in end just get in a good supply of sticking plasters. :y :y :y
Bigron
  • Witham, Essex
Re: Thermostat.
« Reply #8 on: 29 December 2013, 20:05:28 »
What a brilliant site this is! My thanks to one and all; wish the weather were more clement so I could get to it......
Ron.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Thermostat.
« Reply #9 on: 30 December 2013, 09:32:03 »
also buy parts by" can supply but not sure of make :y
