Author Topic: rear blind  (Read 3414 times)
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
rear blind
« on: 30 December 2013, 21:44:33 »
After trying to pull up rear blind by hand and yes breaking one of the plastic bars i have located a replacement. However just for the hell of it i tried the blind again tonight and it worked >:(   Well it went up obviously lopsided ,what i wondered is it possible to replace just the broken plastic bar from my doner one when it arrives or is it not possible  thanks for any info
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Re: rear blind
« Reply #1 on: 30 December 2013, 21:45:37 »
As you have to remove the blind completely in order to repair it, you may as well replace it...
Toledodude1973
  • IPSWICH U.K.
Re: rear blind
« Reply #2 on: 30 December 2013, 21:50:47 »
Thanks TB ive looked at the guide seems fairly ok so thats the route i will take. Any further advice on removal, regretting being so heavy handed at W/e :-[ :'( :'(
Re: rear blind
« Reply #3 on: 30 December 2013, 21:52:28 »
Might be interested in your old one once you have the new one installed and working. ;)
Mine is a bit lazy,so I might be able to make one good one from two.  :y
Re: rear blind
« Reply #4 on: 30 December 2013, 21:53:48 »
This guide covers most things
http://www.omegaowners.com/forum/index.php?topic=90506.0
Toledodude1973
  • IPSWICH U.K.
Re: rear blind
« Reply #5 on: 30 December 2013, 22:00:26 »
Ok albs no problem i'll keep you posted ,expecting replacement in about a week
Re: rear blind
« Reply #6 on: 30 December 2013, 22:02:26 »
Cheers mate.  :y
You still got my phone number ?
Toledodude1973
  • IPSWICH U.K.
Re: rear blind
« Reply #7 on: 30 December 2013, 22:06:24 »
On my friends and family list :y :y :y
Re: rear blind
« Reply #8 on: 30 December 2013, 22:07:58 »
Which is he, friend or family.... ;D
kevinp58
  • kent
    • 2002 3.2 elite
Re: rear blind
« Reply #9 on: 31 December 2013, 01:43:11 »
Did mine a while back and its easy enough but the parcel shelf is tricky to get out but easy to do also Mine was a different colour to the replacement but you can change the top part.  :y Just make sure as you slide the old one off you slide the new one on as it is under a spring load and it will retract and be a bar person to get back.  ;D
Toledodude1973
  • IPSWICH U.K.
Re: rear blind
« Reply #10 on: 03 January 2014, 23:31:12 »
Thanks Kevin just read reply will swap over weekend
