Just buy it Albitz
Started by omega3000, 31 December 2013, 14:30:17
If I had the money I would.  8) :y
Quote from: Albitz on 31 December 2013, 16:03:33
If I had that kind of money kicking about a bank account I'd spend it on something other than a car ;)
I wonder what kind of alternator is fitted to power all the extra lights up  :o
Varche
Not much to go wrong in the engine compartment. In fact not much in there.
I like the spare coil
I had a cam belt snap on mine.Luckily it was at tickover and just bent two exhaust valves. new head would have been over £1000 which was a lot of money in 1981.  ;D
2boxerdogs
If I had that kind of money to spend on a "toy" it would have to be an AC Cobra.
QuoteEngine: All steel 2.6 works Big Valve Head, Dry Sump, 48 Dellortos
Dry sump  ??? Dont know much about that  :-\
Oil held in a separate tank and pumped under pressure around the engine. Fast cornering and changes in direction can force the oil in a traditional wet sump  setup away from the oil pickup and starve the bearings of lubrication. Most really high performance applications use the dry sump system.
Quote from: Albitz on 31 December 2013, 17:46:05.... Most really high performance applications use the dry sump system.
My TDM is dry sumped (the oil level is via a window up under the fuel tank).... not quite sure how that fits into the high performance bracket  ::) ;D ;D
Theres an exception to every rule. :y :y...............I probably should have typed many rather than most tbh.  ::)
Taxi_Driver
I used to have one of those......should have kept it....my first car....tho it was only a 1.3 GLS  :y ;D
Wonder if Albitz went out and put a deposit on the Chevette  :-X
Quote from: Emd on 01 January 2014, 17:17:34
He could afford it. :)
